First time towing...no problem
Old May 28, 2010 | 05:56 PM
10ramisport's Avatar
10ramisport
Default First time towing...no problem
I finally took my first road trip with the Ram towing my '81 T/A to my dads house in Fla from NC. Driving down I-95 using the tow/haul mode with the cruise set at about 70-75, I managed an avg of 13.5 mpg. This truck is amazing! It rides and tows like a dream. Never felt like I was pulling anything. I love it! And on the way back to NC w/o the trailer but carrying a propane grill and 4 tires/rims the truck managed 18.5 mpg at 75 on cruise. Not bad.
Also, before leaving, I installed Timbren SES rubber springs in place of the original bump stops. They look like oversize bump stops on steroids. I knew the rear end would sag with a load and wanted something other than bags in the springs. They work awesome on keeping the truck level with a load. Anyone looking for other than air bags, I would highly recommend the Timbrens!
In mid June, I will definitely put the Ram to the test as I will be moving to Anchorage, Ak driving from Fla. Thank god for VES and Wii to keep the kids busy!!
Old May 28, 2010 | 06:00 PM
matt3's Avatar
matt3
Do you have pics of the springs or a link to them?
Old May 28, 2010 | 06:19 PM
10ramisport
matt3,
www.timbren.com
http://www.aaaspring.com/timbren-ses-kits.html
I believe the part # is DR1500DS for the rear of our trucks. hth
Old May 29, 2010 | 10:39 AM
Sobomaster's Avatar
Sobomaster
So just a little over $180? How long did the install take?
Old May 29, 2010 | 01:09 PM
it's all dodge's Avatar
it's all dodge
What gears do you have? They both look pretty good! Gotta be close to 4700 plus pounds total. Florida to Alaska, man, that'll be a long haul!!
Old May 29, 2010 | 02:38 PM
ram09red's Avatar
ram09red
Did you have to remove anything to do the install? Perhaps some pics
Old May 29, 2010 | 02:54 PM
10ramisport
It took me less than an hour to install. Pretty easy. I'll try to take some pics of them installed. At the time of installing, I didn't have my camera. Here is the instructions that came with the springs:
http://www.timbren.com/timbren-appli...s/DR1500DS.pdf
I have the 3.92 LSD setup.
Old May 29, 2010 | 03:07 PM
kevinc66's Avatar
kevinc66
Yea, that U-Haul auto-transport is the same one I'm gonna tow my Stang Vert in early July, I'm looking at about 3500lbs, going from Ft Sill,Ok to El Paso,Tx(650 miles) So I guess the light wiring from the trailor plugs right into our bumper huh? Wish me luck, I've never towed anything before, I figure if I don't go over 65mph I'll be alright.
Old May 29, 2010 | 04:01 PM
10ramisport
That was my first time towing also. I used the side mirrors a lot! The trailer light plug goes into the top connector on our trucks. I cruised about 70-75 with no issues at all.
The only issue I had was when I returned the trailer and the uhaul folks wanted me to back it in a certain spot...now that sucked for a first timer! Good Luck!
Old May 29, 2010 | 04:38 PM
kevinc66's Avatar
kevinc66
Yea, I'm not looking forward to having to back the trailor up as well, I figure when I go to U-Haul in El Paso, I'll pull in, disconnect in a open area and go in and settle up,lol lol.
