black grille?
Do you want the full grille or just the insert? Both are available, neither discontinued.
If the full grille, you'll have to decide which inserts to buy it with. The TRX grille has the black honeycomb, can be had for $225-30 ish shipped. The newest Sport grille has the chrome billet insert but also costs more.
I've got a black insert if that is all you are after.
Trending Topics
BigTexMarine, then you want the TRX grille. Has a black shell with the black honeycomb insert. The part number for that was 1KX581XRAB. Better check on the number though as it's been a little while. Showing $219.80 at the dealer in Ohio that a lot of us were ordering from, slightly higher than before. So add shipping and you are probably just under $250.
bls8195, do you want the whole grille or just the inserts? I have a set of the black honeycomb inserts.
War Horse, I still have the silver grille, just added the billet inserts. Same as a 2010 Sport, well a later year build.
