Speaker question
Old Jun 11, 2010 | 10:41 PM
myhikingboots's Avatar
myhikingboots
Originally Posted by plumcrazy73
OK other then Infinity's what else is everyone running?
In Iraq now, can't get to my truck to do measurements, and I am trying to have the equipment waiting on me when I get home
Just out of curiosity, why not Infinity? I just installed some 6 x 9 2-ways in the front doors. I had to do a little carving to the door bracket behind the magnet, and use the supplied spacers and longer mounting screws but everything works great. According to Crutchfield neither the Polks nor the Infinitys will fit, but I think that you would have no problem if you're a little adventurous. I also have 3.5 Kappas on order for the dash.
I picked the Infinitys because of there high efficiency and I'm trying to get the most out of the factory head unit.
Here's a link http://https://dodgeforum.com/forum/...xperience.html from early this year with lots of pics and tips thanks to Eternalodyssey.
Old Jun 12, 2010 | 03:38 AM
plumcrazy73's Avatar
plumcrazy73
because I am not going to be using a head unit, and infinity's ohom rating is not 4 ohm they ae 2 ohm , they say 4 ohm with the wire but I have read that is more like 2.9-3.something. And I am going to be running an amp and running the 6x9's off one pair of the channels (2 ohm stereo) and that would put them at less then 2 ohm stereo. Don't want to burn up an amp
Old Jun 12, 2010 | 05:31 AM
bigred3297's Avatar
bigred3297
If each speaker is 2ohm, just buy a 2ohm capable amp....Your final impedence will not drop with wire but instead it will rise, you will also recieve more power running them at 2ohm as opposed to 4ohm
Old Jun 12, 2010 | 09:41 AM
seigell's Avatar
seigell
Originally Posted by bosssman
They arent required but my audio guy showed me the difference in sound quality, it was night and day....mind you I already had the 4x6x9's to put in.
Do you mean that your installer simply replaced the stock 6x9 fronts with full-range 6x9s ?? Without replacing anything else in the door speaker circuit ?? In an older thread, it was said that the front doors were on a low-pass filter circuit - meaning any replacement without major rewiring would be the same bass-only. It meant to me that simply replacing speakers wouldn't improve the situation.
And that put me off of any thoughts of a quick speaker upgrade...
But if it's simply the door speakers, or some low-pass filter build directly into the stock speakers, then I'll have to start thinking about this upgrade again. I'd really like to move the sound "focus" away from the center dash speaker...
Old Jun 12, 2010 | 09:44 AM
mixgt's Avatar
mixgt
Crutchfield will tell you if they would fit or not.
Old Jun 12, 2010 | 07:03 PM
myhikingboots
My guess is that it is a low pass from the radio. I chose the 2-way 6x9s as oppossed as to the three ways because I wasn't worried about the upper end. I just wanted better woofer cones and BETTER bass than the stock door speakers.
Old Jun 12, 2010 | 08:14 PM
plumcrazy73
no cause crutchfield says infinity's won't work but people get them in so i don't like them anymore I liked it when they published specs, IE Tweeter protrusion that you are allowed for a vehicle or depth etc etc
Old Jun 12, 2010 | 10:05 PM
mixgt's Avatar
mixgt
Good to know. Bummer I didnt buy the Infinity cause they said it wouldnt fit. Dammit
