Left cigarette lighter not working 2010 RAM 1500
Old Jul 18, 2010 | 11:51 PM
awful knawful's Avatar
awful knawful
Originally Posted by BigBlueEdge
Still trying to figure out what the 'left' one is?? Rob
on the trucks with no console there are 2 12v plugs. 1 on the left side of the cup holders and 1 on the right side (small white things)
Old Jul 18, 2010 | 11:58 PM
BigBlueEdge's Avatar
BigBlueEdge
Thanks for the enlightenment about 'left'! I guess I've never been in a model without the console. Rob
Old Jul 19, 2010 | 12:34 AM
oldjeep's Avatar
oldjeep
If you don't have a center console (bench seat with column shift) there is a lighter socket on each side of the flip down console.
Old Jul 20, 2010 | 07:48 PM
brzelt's Avatar
brzelt
I have the center console and my outlet (by shifter) off the ignition did not work as well.
Turns out a dime dropped in the hole....
Anywhoo, a change of fuse M48 fixed it right up.
Old Jul 22, 2010 | 04:43 PM
JB007Rules's Avatar
JB007Rules
Originally Posted by ffjeeper
is there a fuse in the cell phone charger? sometimes the end cap unscrews to reveal a fuse.
Apparently NOONE READS these days!?!?!?! Read my first post! "NOTHING works in the left outlet" - as in NOTHING works... so for an FYI that cell charger (and my toughbook charger, nav and inverter for that matter) ALL work FINE in the right outlet...
Old Jul 22, 2010 | 04:44 PM
JB007Rules's Avatar
JB007Rules
Originally Posted by oldjeep
Left one is on its own 20 amp fuse - I know since I just burned it out when my garmin cord shorted out. Might want to try another 12V device in that socket and see if it works.
When you pulled the dash apart did you stick a volt meter on it? If you don't own one you're kind of wasting your time trying to track down electrical issues.
I will check it right now with a volt meter as I do have one...
Old Jul 22, 2010 | 04:45 PM
JB007Rules's Avatar
JB007Rules
I will most def try switching out fuse M48! Thanks
Old Jul 22, 2010 | 04:51 PM
JB007Rules's Avatar
JB007Rules
HOLY CRAP! So brzelt you are a freakin' genious!!!!!!! Sure as hell that fuse was blown! I replaced it and vwala! Perfecto!
So with that being said, either I missed it entirely when testing them or my father in laws fuse tester is broken (Probably I missed it).
Thanks for the help everyone!!
Old Jul 23, 2010 | 07:18 AM
brzelt's Avatar
brzelt
Glad to be able to help.
Old Feb 24, 2015 | 03:36 PM
Danielerickson's Avatar
Danielerickson
Default I have the same issue
I also have he left cig lighter in my truck like you I checked all the fuses and even got inside my dash and made sure everything was hooked up and not somehow gotten knocked loose but it's not just my cig lighter out my left turn signal is out I replaced the bulb and still it says it's out and does not work so I figure mabey I got te luck of the draw and got a difective bulb so went and got another still no turn signal I am really disappointed in dodge I'm 36 and I have alwayse owned a dodge actually I've never owned Any other car than dodge but it feels time to throw in the towel
