Throttle body modified
Old Jul 28, 2010 | 08:56 AM
thmupr's Avatar
thmupr
Originally Posted by renos09
I had my stock throttle body modified a few mm larger and tapered and I can't believe how much better the throttle response is and also has more punch when I step on the gas. Best mod I did so far.
Did you go 85mm mod or 87mm mod? I see that Modern Muscle offers both.
Old Jul 28, 2010 | 09:47 AM
renos09's Avatar
renos09
85mm. 87 mm is for modified engines.
Old Jul 28, 2010 | 09:50 AM
renos09's Avatar
renos09
I do have an increase in mpg. I drive the same route and the last two days I have been in the 15 to 15.7 mpg range for city driiving. I'll know better when the tank is finished. Power wise the truck is definitely quicker off the line, a bit less drag.
Old Jul 28, 2010 | 04:09 PM
Oosik's Avatar
Oosik
What's the advantage of increasing the size of the Throttle Body rather than just adding a spacer?
Old Jul 29, 2010 | 10:10 AM
Twist's Avatar
Twist
Originally Posted by jayman84
thanks. I will have to give them a call. So did you notice a difference off the line or up higher in the rpms. And have you had any issues at all with it so far?
I have noticed that the engine just runs better, smoother, and slight power increase with the TB change. The biggest change I noticed was how smooth the engine runs from idle on up. Its hard to describe, but you will notice a change. I have had it on the truck for 12K miles now and no problems with it at all.
Old Jul 29, 2010 | 11:45 AM
MADMAXIN22's Avatar
MADMAXIN22
$350+ for a tb?? wtf
Old Jul 29, 2010 | 02:22 PM
hounddogg's Avatar
hounddogg
Spacers do nothing on port or direct injected engines. Only on Throttle body or carbed engines.I used a Fastman on my 1998 318 SLT.$350? I dunno but he dosen't give them away.Its a exchange unit.Go to his site and price one.
Old Jul 29, 2010 | 03:48 PM
pdavis53's Avatar
pdavis53
$212 from Fast Man Dan. he has some really good stuff. Plus he answers the phone when you call, so you actually speak to the person who is doing the work.
Old Jul 30, 2010 | 07:35 AM
Twist's Avatar
Twist
I have used Fastman's TB's in the past and they are very good. I would recommend them also. Modern Muscle uses a different technique than Fastman and I tought I would try it on the hemi. To me it seems to be a better design, but I am no engineer.
Old Aug 2, 2010 | 09:24 PM
lineman07's Avatar
lineman07
where would i find modern muscle website ??
