Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
- Dodge Ram 2009-Present: How to Change Power Steering Fluid
Step by step intructions for the do-it-yourself repairs.
Fluid Capacities?
FLUIDS, LUBRICANTS AND GENUINE PARTS
ENGINE
Component Fluid, Lubricant, or Genuine Part
Engine Coolant MOPARŽ Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology)
Engine Oil (3.7L, 4.7L, and 5.7L Engines) Use API Certified SAE 5W-20 Engine Oil, meeting the requirements of Chrysler Material Standard MS-6395. Refer to your engine oil filler cap for correct SAE grade.
Engine Oil Filter MOPARŽ Engine Oil Filter (P/N 04884899AB) or equivalent
Spark Plugs (3.7L Engine) ZFR6F-11G (Gap 0.043 in [1.09 mm])
Spark Plugs (4.7L Engine) Upper Bank — FR8TE2 (Gap 0.039 in [.99 mm])
Lower Bank — FR8T1332 (Gap 0.051 in [1.30 mm])
Spark Plugs (5.7L Engine) LZFR5C–11 (Gap 0.043 in [1.09 mm])
Fuel Selection (3.7L and 4.7L Engines) 87 Octane
Fuel Selection (5.7L Engine) 87 Octane Acceptable - 89 Octane Recommended
CHASSIS
Automatic Transmission MOPARŽ ATF+4 Automatic Transmission Fluid
Transfer Case MOPARŽ ATF+4 Automatic Transmission Fluid
NVG 246 Automatic Transfer Case Only MOPARŽ PN 05179014AA, NVG 246 Automatic Transmission Fluid or equivalent.
C205FD Front Axle GL-5 SAE 75W-90 (MS-9763) or equivalent.
9.25 Rear Axle MOPARŽ Synthetic Gear Lubricant SAE 75W-140 (MS-8985).
Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPARŽ Limited Slip Additive or equivalent.
Brake Master Cylinder MOPARŽ DOT 3 and SAE J1703 or equivalent. If DOT 3 brake fluid is not available, then DOT 4 is acceptable. Use only recommended brake fluids.
Power Steering Reservoir MOPARŽ ATF+4 Automatic Transmission Fluid
FLUID CAPACITIES
Description U.S. Metric
Fuel (Approximate)
Regular Cab Shortbed/Crew Quad Cab Models 26 Gallons 98 Liters
Regular Cab Longbed/Crew Quad Cab Models (Optional) 32 Gallons 121 Liters
Engine Oil with Filter
3.7L Engine (SAE 5W-20, API Certified) 5 Quarts 4.7 Liters
4.7L Engine (SAE 5W-20, API Certified) 6 Quarts 5.7 Liters
5.7L Engine (SAE 5W-20, API Certified) 7 Quarts 6.6 Liters
Cooling System
3.7L Engine (MOPAR Ž Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent 14 Quarts 13 Liters
4.7L Engine (MOPAR Ž Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent 14 Quarts 13 Liters
5.7L Engine (MOPAR Ž Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent 16 Quarts 15 Liters
A/C Refrigerant System
All Models 1.604 Pounds 0.728 Kilograms
Service Fill - 42RLE 4.0 Quarts 3.8 Liters
Overhaul Fill - 42RLE 8.7 Quarts ♦ 8.3 Liters
Service Fill - 45RFE/545RFE 4X2 - 5.5 Quarts 4X2 - 5.2 Liters
4X4 -6.5 Quarts 4X4 - 6.2 Liters
Overhaul - 45RFE/545RFE 14.8–16.9 Quarts ♦ 14-16 Liters
♦ Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. (Refer to 21 - Transmission and Transfer Case/Automatic - 42RLE/FLUID and FILTER - Standard Procedure) (Refer to 21 - Transmission and Transfer Case/Automatic - 45RFE/545RFE/FLUID and FILTER - Standard Procedure)
Transfer Case
NV 243 3.4 Pints 1.6 Liters
NV 246 4.0 Pints 1.9 Liters
Axles
C205FD Front Axle 56 ounces 1.6 Liters
**9.25 Rear Axle 74 ounces 2.2 Liters
**Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPARŽ Limited Slip Additive or equivalent.
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
ENGINE
CHASSIS
FLUID CAPACITIES
Fuel (Approximate)
Cooling System
Transfer Case
Axles
Is dealer correct?
Was in today for some RRT work. He said it was also time for trans / diff / transaxle fluid changes. He quoted about $350 to do it all, way more than I can afford. I told him no, i'll do it myself and he said:
" the transmission and both differentials need friction modifier"
Really, in the tranny?
And I am pretty sure I don't have a limited slip rear diffy, so why would I need it in the front and rear diffy's? I think this guy is FOS but I need to make sure.
09 quad hemi 4x4 1/2 ton.
Trending Topics
