2010 Power Wagon Low Range Operation
Regarding my 2010 Dodge Power Wagon. In low range and in first gear when navigating a steep descent I use the engine and the gearing to hold the vehicle back. I noticed that with this particular vehicle, the engine RPM's fluctuate quite a bit (±1500-1800 RPM) allowing the vehicle to accelerate and then slow down and then accelerate and slow down again. There doesn't seem to be any predictability to the fluctuation and this is the first Dodge that I have had this happen with. Is there something wrong? Thanks.
Also could this be related to intermittent surging under hard acceleration? It sometimes feels like it is being held back and then suddenly “let go” while accelerating aggressively. Thanks again.
Ike
Ike
Thanks for the replies. But it just doesn't make any sense to me. Let's say you are navigating (idling) down a steep slippery slope in low range and your engine rpms increase as does your vehicle speed due to this program, then suddenly your rpms decrease forcing the vehicle to slow as well which could cause you to break traction and lose control. Just seems odd. Is there a way to switch it off??
Power Wagon: Is the truck shifting between gears when this 'surging' occurs? If not, then it is not torque management, at least as far as I understand torque management. I'm always open to being corrected with better facts than I have though.
Rob
Rob
Ike
Trending Topics
I am willing to bet that your ECU is trying to get your engine to idle... as speed drops the truck adds fuel as it thinks it is about to stall... the truck surges as the additional fuel is burnt... then the truck speeds up which means the ECU no longer thinks it is about to stall so it cuts fuel so rpms drop....
It is a symptom of not quite developed engine control software, and an electronic throttle.
Full disclosure: This is my theory based on your symptoms and my previous experience.
