High Pitched Whistle/Whine right at 45-50 mph
Old Oct 12, 2010 | 04:23 PM
a_gunslinger's Avatar
a_gunslinger
Originally Posted by Rizam
I had the SAME EXACT issue and made a video.... is it like this???
No not it
Old Oct 12, 2010 | 05:56 PM
USAF1's Avatar
USAF1
Might want to print out this thread to let the dealers know its not an isolated case.
Old Oct 13, 2010 | 06:57 PM
a_gunslinger
Default Verdict in
Got the call from the dealer today. Defintiely thought it was the differential and pinions. Thought about a shim but felt the shim alone was only part of it. Pretty much all new pinions and parts in the differential and putting one shim in as well tomorrow. Will report of success.
And guess what. He said he got a call from another new truck owner reporting the same issue at about same speeds. He said "I think I know what it is, as of today."
But they cant figure out what the driveline vibration is at low accel in various speed points
Old Oct 14, 2010 | 02:21 PM
Jgroes's Avatar
Jgroes
Originally Posted by a_gunslinger
Glad Im not alone, but sorry you have it also. Mine is at dealer now for that. Definitely rear end, when you turn head to right to listed to rear its even mmore noticeable. Made service rep go for ride with me and he definitely heard it and said "Yep, thats not right." Make them go hear it so you dont get that dreaded call saying "Could not duplicate condition." Especially if they drive it with windows open its not as noticeable.
I also have soem strange "rough: spots in the drive train at or near shift points when giving just slight gas. Thankfully they felt that as well. They think they might be related (but not so sure).
I should get a call later today or tomorrow and will post their findings.
Very interesting. I just started to notice the same condition at steady highway speeds between 55-65. I've got a 10' with the 5.7 / 3.92's w/ a little over 22K miles on the engine. I'll take it in and go for a drive with with the tech. Appreciate you keeping us posted.
Best regards,
JG
Old Jan 17, 2011 | 06:50 PM
luc007's Avatar
luc007
Default Whining noise
To whoever it may concern, I have experienced this very annoying whining noise on my 2010 RAM Hemi between the speed of 45 and 55 mph. The problem has been solved by the dealer : the reason of this noise is a defective bearing inside the rear differential. They replaced it (warranty) and the sound is GONE ! it was driving me nuts and thanks god they could solve the problem :-)
Old Jan 18, 2011 | 12:32 PM
a_gunslinger
Well, don't want to burst your bubble but mine started again after a month after the first repair. They totally did an about face and changed approach in facing an issue they can't fix. The first time it was "That's not right adn we need to replace differential components". Now its "Thats as-per-design and when they new parts ar einstalled its quiet until they all get broken in then they whistle again." Short for We Screwed Up and There Will Be No Fix.
Old Jan 19, 2011 | 12:25 PM
luc007's Avatar
luc007
I just hope I will not have to go trough the same .... as well I never experienced the rough spots in the drivetrain and near shift points you were talking about, maybe your problem is more complicated ? will keep you posted if anything goes wrong again on my side.
Old Feb 23, 2011 | 12:12 PM
luc007's Avatar
luc007
Default whining noise
So far, so good, the noise never came back and I enjoy driving my truck.
I guess they made the right thing by replacing this defective bearing in the rear differential.
02/23/11
Old Feb 23, 2011 | 04:04 PM
pfd161's Avatar
pfd161
this is the same noise as reported in the thread about the torque converter issue....
https://dodgeforum.com/forum/4th-gen...ing-noise.html
Old Feb 24, 2011 | 01:37 PM
rickabev's Avatar
rickabev
I had the same issue and took mine to the dealer just a few days ago. They said that they had 3 different techs take it for a test drive and all of them reported it as normal driveline sounds... I'll definitely be following this thread as I'm sure there is a cause for it. Keep us posted.
