bed rails with bed cover
Old Oct 2, 2010 | 07:55 AM
2010White1500's Avatar
2010White1500
Default bed rails with bed cover
hey guys just baught my first dodge truck (2010 ram 1500 ST reg. cab 4x4 w/ 3.92's) and was looking into getting myself a set of bed rails and would really like a cover for long road trips... thats where its look like i ran into a problem.
my question is: is there any combination of the two that will work together? (bed rails and cover)
thanks guys.
Old Oct 2, 2010 | 12:58 PM
Laramie1997's Avatar
Laramie1997
The only thing I can think of would be a soft rolling cover that fits down in between the rails and the bed. They have a track system that they slide on and the roll is at the front of the bed obviously. I haven't looked for them on our rams, but I'm sure they are out there.
Old Oct 2, 2010 | 01:32 PM
oldjeep's Avatar
oldjeep
I'm assuming you are talking about those tubular things that serve no purpose?
YOu could probabally use bedrails with a Bakflip. The backflip frame only covers about 1/2" of the rail. Otherwise there are a couple covers that sit entirely inside the bed.
Otherwise if you are talking about something like a Trac-Rac or Vantech rack, there is just enough room to get one of those on and still open a backflip between the uprights. I've got the vantec version on mine.
Old Oct 2, 2010 | 03:08 PM
05Dakotaho's Avatar
05Dakotaho
They make good connectors for tie down straps when the bed is loaded with all the $hit your girlfriend lets ya' keep for your weekend move-out.
Old Oct 2, 2010 | 10:17 PM
2010White1500
i like the idea of having something that dont look to bad and gives me the possibility of multiple tie down points. no need for a ladder rack at this point but if i find a cover that fits with the bed rails then they should deff. fit the trac-rac or other ladder racks. thanks guys
Old Oct 3, 2010 | 02:46 AM
isac_andrei's Avatar
isac_andrei
check truxedo lo pro qt
Old Oct 3, 2010 | 08:31 AM
2010White1500
i like the truxedo especially bc its a little cheaper than others but i have one more question... will any of these covers work with a sliding tool box? i know they fit inside the bed as well but cant be sure the mounting rails will interfer with one anyother thanks again
Old Oct 3, 2010 | 10:55 AM
azrm10's Avatar
azrm10
http://www.peragon.com/
Old Dec 8, 2010 | 09:02 AM
'05Train's Avatar
'05Train
I'm thinking they should work with a Bakflip.
But....Do you have to cut the plastic rail cover over the front stake pocket?
Old Dec 8, 2010 | 11:00 AM
ksfis43's Avatar
ksfis43
I was looking at doing this too, Did you find a combination that works??
