Help with headlight swap.
Old Oct 28, 2010 | 11:59 AM
sneeks's Avatar
sneeks
Default Help with headlight swap.
I remember faintly someone posting a DIY post on removing the headlights for the placement of their HIDs. I'm not having any luck finding that post, anyone have any clue who it was or where the post was? I'm trying to see what I can tap into to activate the LED's in the new Recon projector headlights that I bought. Need a positive and ground that aren't always on, that are in the general area. I'm guessing the design of these headlamps were to always have the LED's on. That's one thing I am unclear on.
Old Oct 28, 2010 | 12:12 PM
sneeks's Avatar
sneeks
I jumped the gun making this post, i found it shortly there after.
https://dodgeforum.com/forum/4th-gen...installed.html
credit to Lancelanz
Old Oct 28, 2010 | 12:13 PM
sneeks's Avatar
sneeks
Just gotta figure out what to tap into for power and ground for the LED's now.
Old Nov 18, 2010 | 01:29 AM
InterpunX's Avatar
InterpunX
Did you end up installing those headlights? I just bought the same from recon now i was just wondering what to wire them to. I figured probably the parking lights.
Old Nov 21, 2010 | 01:46 PM
jayman84's Avatar
jayman84
I would also like to see what they look like installed and what kind of bulb did you put in them for the headlights.
Old Nov 22, 2010 | 04:56 PM
InterpunX's Avatar
InterpunX
I finally went and put them on, they look great and i love them, i wired the halos and leds with parking lights. once theyre installed you just have to adjust the low and high beams to your likings. overall the lowbeams are pretty much just as bright as stock but highbeams are much brighter.
Old Nov 22, 2010 | 07:36 PM
jayman84's Avatar
jayman84
those look awesome on your rig. that will be on my upgrade list for this spring for sure.
Old Sep 30, 2012 | 09:18 AM
ImRonnie's Avatar
ImRonnie
Can you install a dual bulb headlight setup in a stock single bulb headlight?
Old Sep 30, 2012 | 09:53 AM
12Sport's Avatar
12Sport
No the housings are different but with a housing swap and rewire I would think you should be able to.
Old Sep 30, 2012 | 11:14 AM
ImRonnie's Avatar
ImRonnie
What if you are taking the stock headlight housing from a dual bulb 2010 to a 2009 single bulb? Is the housing not the same?
