Mopar Pedals?
Old Nov 8, 2010 | 10:52 PM
the2nd2lastfaul's Avatar
the2nd2lastfaul
Default Mopar Pedals?
I really like the mopar pedals. Does anyone know why the won't work with the adjustable pedals? I have the adj pedals but never move them. What kinda problem could these mopar pedals cause? Here is a link so everyone knows what I am talking about. Thanks
http://www.moparonlineparts.com/part...catalogid=5399
Old Nov 9, 2010 | 02:25 AM
kxwhite's Avatar
kxwhite
i have them on my non-power pedals.... the only thing i can figure is the power pedals must be a different size so they wouldnt fit on. they dont bolt on, they slip on using clips and a rubber wrap around
Old Nov 9, 2010 | 09:08 AM
the2nd2lastfaul
Do you have a pic of your pedals with the covers off. I would like to see if they are shaped differently. I thought they said not for use with the power pedals because they caused them to hit the floor or something when moved. Thanks
Old Nov 9, 2010 | 05:39 PM
eclipsems's Avatar
eclipsems
I have the adjustable pedals, and got the Mopar pedals to fit. Had them for 3 months now and never experienced any issues with them hitting the floor.
Actually, I don't see how they would cause an issue. The pedals don't add any more bulk to them in behind the pedals.
Mind you, it was difficult to get them on. You have to put them in hot water to get them flexible enough to fit.
Old Nov 9, 2010 | 05:47 PM
the2nd2lastfaul
They arn't made out of metal? Or is the front metal and the back rubber that has to be put in hot water to get them to fit? So the adjustable pedals are different in shape than the non adjustable pedals. Or are they all this hard to get on? For almost $100 it shouldn't be this hard! They should make some for adj pedals if they are gonna have some that exclude them!
Old Nov 9, 2010 | 10:59 PM
eclipsems's Avatar
eclipsems
They are predominately made of rubber, with just metal inserts on the front face.
The gas pedal was easy, but the brake pedal took some frequent dips into hot water, and brought out the darker side of my vocabulary. Took me a good 30 minutes to get it on.
Old Nov 11, 2010 | 01:51 AM
kxwhite's Avatar
kxwhite
ya with my non power pedals it was a major pain in the *** to get that brake pedal on too! I used hot water and two flat screw drivers to pry it into place.... it was probably took me 30 min too!
Old Nov 11, 2010 | 08:43 AM
the2nd2lastfaul
Do yall think they are worth the money? Thats alot of money for something that states that I shouldn't use it on my truck and is so hard to put on! Where did you guys buy them from?
Old Nov 11, 2010 | 09:58 PM
kxwhite's Avatar
kxwhite
bought mine at the dealership, i like it just because its something to different. I know when my buddies jump into my truck to drive it they notice two things when they get in, my door sills and my pedals.
