4 wheel drive episode
Old Nov 14, 2010 | 08:44 PM
DroopyDog's Avatar
DroopyDog
Default 4 wheel drive episode
Yesterday I was in Minneapolis, MN as they were getting 9" of heavy wet snow. I'm using 4 wheel drive when I pull up to my brother-in-laws house and attempt to put the truck in park. It was difficult but when I got it in Park it actually went into reverse and made some grinding noise. Got it stopped and turned off the engine. when I tried to restart it nothing happened. So I took the lockout tab loose and pressed the button and everything worked fine. I the took it out of 4 wheel drive. Today I drove back to Des Moines and everything still appears to be fine. What happened and should I take it in to Dodge?
Old Nov 14, 2010 | 09:14 PM
mike2810's Avatar
mike2810
Read the thread " Warning when driving in slushy snow! ". The OP had the same thing happen. Most likely your transmission and transfer case was packed with snow.
Old Nov 14, 2010 | 10:31 PM
05Dakotaho's Avatar
05Dakotaho
Another "Sport" with the same problem. Hmmmmmmmm
Old Nov 15, 2010 | 06:06 AM
1954Radio's Avatar
1954Radio
This doesn't look good for us Dodge Boys!
Old Nov 15, 2010 | 11:55 AM
USAF1's Avatar
USAF1
Originally Posted by DroopyDog
Yesterday I was in Minneapolis, MN as they were getting 9" of heavy wet son. I'm using 4 wheel drive when I pull up to my brother-in-laws house and attempt to put the truck in park. It was difficult but when I got it in Park it actually went into reverse and made some grinding noise. Got it stopped and turned off the engine. when I tried to restart it nothing happened. So I took the lockout tab loose and pressed the button and everything worked fine. I the took it out of 4 wheel drive. Today I drove back to Des Moines and everything still appears to be fine. What happened and should I take it in to Dodge?
Where is the lockout tab and what button did you press? Need to know before it happens to me in mountains with no cell phone coverage. Tx.
Old Nov 15, 2010 | 12:08 PM
Laramie1997's Avatar
Laramie1997
I think he's talking about the neutral button next to the 4x4 system. I could be wrong, but it is the only thing that is coming to mind concerning a "lock out tab".
Old Nov 15, 2010 | 04:52 PM
MADMAXIN22's Avatar
MADMAXIN22
im just glad they finally made a bulletin for the fuel filler neck issue.... not looking foward to this being another since i love driving in the snow!! maybe a shield is need somewhere
Old Nov 15, 2010 | 05:25 PM
newmexicoram's Avatar
newmexicoram
I wonder if this would happen with the factory skid plates installed??
Old Nov 15, 2010 | 05:30 PM
05Dakotaho's Avatar
05Dakotaho
He could mean this:
Page 314 (2009 Owners Manual) Center Console Shifter
(could not paste the photo-sorry)
There is an override for the BTSI that allows you to move
the shift lever out of the PARK position if an electrical
system malfunction occurs (i.e., dead battery). To access
the override (using a flat-bladed screwdriver), carefully
remove the override cover which is located on the right
of the shift lever gate.
1. Turn the key to the ACC or ON position without
starting the engine.
2. Firmly set the parking brake.
3. Press and maintain firm pressure on the brake pedal.
4. Using the screwdriver, press and hold the override tab
through the access port on the center console.
5. Move the shift lever into the NEUTRAL position.
6. The vehicle may then be started in NEUTRAL.
7. Reinstall the override cover.
Old Nov 15, 2010 | 07:19 PM
hardcharger77's Avatar
hardcharger77
He could mean this:
I wondered what that little cover was for. Thanks for the info!
