15 minutes to fuel up.
Old Nov 25, 2010 | 06:46 PM
rdculus's Avatar
rdculus
i noticed the same thing on my '10. I pulled the nozzle out half way and then it worked. I think the fuel nozzles get finicky in the cold weather. I dont have any trouble unless its really cold out.
Old Nov 25, 2010 | 10:17 PM
Dennis01's Avatar
Dennis01
Originally Posted by Laramie1997
Actually, it's probably the way you inserted the nozzle into the gas filler neck. It seems that the new(er) designs have to be seated in there just right before they will actually work. I've had this problem once on my 10 ram where it kept clicking like it was full. The 08 and up challengers and chargers had this issue as well. If you move the nozzle out a bit or reposition it, I'd be willing to bet that the problem would go away.
I tried posistioning the nozzle several times while filling up. The dealership told me that the fuel tank vents into some kind of cylinder (can't remember the tecnical name) and they sometimes have issues with it. Either mud, snow etc. and they have to drop the tank and replace this thing. Does this make any sence? It wasn't the pump, I filled up today at a different place and it wasn't quite as bad, but was still way slower than normal.
Old Nov 26, 2010 | 01:17 AM
Laramie1997's Avatar
Laramie1997
I wonder if the filler neck on yours had those clips break on it making the ordeal complicated?
Outside of that, I've not driven mine in snow yet. We had our first array of it today which amounted to a dusting and it will be gone tomorrow with highs in the 60's. Guess I'll face this and the shifting problem when snow is on the ground.
Old Nov 26, 2010 | 01:24 AM
canadian dakota's Avatar
canadian dakota
i had the same issue with the dak (08) no matter what pump i went to eventually after month it just stopped IDK never had it looked into any further
Old Nov 26, 2010 | 06:41 AM
WTEBOY703's Avatar
WTEBOY703
Canadian Dakota you traiter even postin in here now? lol think your name tags gonna have to change! lol but i never had this problem kinda weird though!
Old Nov 26, 2010 | 12:39 PM
HEMI5150's Avatar
HEMI5150
Well it sounds like you better take a trip to your stealership and have it looked at then.
Old Nov 27, 2010 | 07:34 AM
Dennis01's Avatar
Dennis01
I booked an appointment at the stealership (i like that) for next Thurs. will post results.
Old Nov 28, 2010 | 01:33 PM
HEMI5150's Avatar
HEMI5150
Absolutely yes, let us all know what the result/outcome is and what they did to fix it
Old Dec 3, 2010 | 08:09 AM
Dennis01's Avatar
Dennis01
Just to update on my filling issue. Since the weather has warmed up considerably I have not had any problems filling up. Dealership tells me that they have had the same issues with other trucks that have a lot of snow and ice build up under them in very cold weather and that for sure it was the tank vent freezing. They did not know however why my cruise control decided to not work for a couple days then started working (cruise light would come on when set but wouldn't engage). Maybe like me it just needed a rest?????
Old Dec 5, 2010 | 08:51 PM
deke6520's Avatar
deke6520
Out here in Alberta Canada we just came out of a few weeks of -20 to -30 degree weather with lots of snow. No issues with filling up on my truck!
