WHy is my truck cutting out under WOT?
Old Nov 26, 2010 | 07:26 PM
JoesBrotherRamMan's Avatar
JoesBrotherRamMan
Originally Posted by 72combo
Ya I need to get a programmer if only for that,it's like putting your face into the windshield when it hits . I think I would set mine to go as fast as the Speedo
lmao, exactly!
Old Nov 27, 2010 | 03:43 AM
Laramie1997's Avatar
Laramie1997
Interesting... Mine tops out at 115. Weird.
Old Nov 27, 2010 | 07:01 AM
1954Radio's Avatar
1954Radio
Everyone uses the word governor, does anyone actually know how it works in our trucks? Primitive governors such as centrifugal designs found in pressure washers, lawn mowers are linked to the cam and carb are controlled by spring and older model vehicles were linked to the distributor and carb and were controlled by vacuum. Later vehicles are controlled electronically, so are our trucks controlled by an electronic module such as a servo motor and monitored by sensors? Does the ECM control the servo if there is one or just the sensors? Because if it's linked directly to either one such as your ABS which is controlled by electronic pulses, why is it called a governor when ABS is not, lol? Or better yet...why isn't ABS considered a governor
Old Nov 27, 2010 | 11:01 AM
TheDarkFox's Avatar
TheDarkFox
The speed limiter on our trucks does not actuate the break. As far as i can tell it electronically cuts back the fuel flow back to idle levels and waits for the vehicle to decelerate back below the threshold before allowing more fuel to be delivered again.
Old Nov 27, 2010 | 12:15 PM
1954Radio's Avatar
1954Radio
yes, it makes sense...but that is still done because of sensors feeding the ecm which in turn tells the ecm to send electronic pulses to an electronic servo motor on the throttle body to deactivate it when you reach the end of the envelope, in this case around 105 or or possibly rpm and or tire spin, I'm not sure, could be all of the above. However...it will still do it even if you don't reach 105 while you are power braking...I know, it's done it to mine (cut out) which tells me it can also be applied by the ABS or RPM's. My truck effortlessly smokes both tires when power braking and cuts off at to too high of rpm or possibly tire spin, rpm or both, and I do not have a tuner. However, it will not cut off if I pepper the throttle to WOT by fooling the ecm and can smoke them non stop while power braking till my face turns blue. Everything on these trucks are controlled by electronic pulses in various frequencies...from your engine and drive train, to your brakes. So as far as I'm concerned, everything affecting the performance of these trucks, including tire spin...is controlled by electronic governing from sensors feeding your ecm. It seems to be the only way logical, but correct me if I'm wrong...I'm still learning just like everyone else.
Old Nov 27, 2010 | 02:04 PM
TheDarkFox's Avatar
TheDarkFox
It's only an issue for those using the factory settings. Most of the performance junkies are using aftermarket parts and programmers anyway.
Old Nov 27, 2010 | 02:33 PM
POWER SEDAN's Avatar
POWER SEDAN
It used to be the top speed was based on what the speed rating of the tires from the factory were rated at. That could be why some are 105, and others are 115. Not sure it that's the way these govenors set now though.
Gen. 2 Rams had a pressure sensor which would cut the fuel supply (I believe) now they just program the ECM to whatever speed rating (possibly based on tire rating) is safe for the tires. Considering it takes all but a few seconds to over ride the ECM through a Diablo tuner, I can't imagine it's much more then a preset figure within your ECM.
Old Nov 27, 2010 | 08:22 PM
1954Radio's Avatar
1954Radio
Key word: "GOVERNOR"...one and only one if it is one...the ECM, lol! Everyone knows they can be re-programed, lol!. Fact: these trucks are governed by electronic pulses in various frequencies. Does the ECM alone (my opinion) send out the pulses, or do the sensors send them out as well...could someone PLEASE elaborate, lol! I think the sensors feed info to the ECM and the ECM sends out the pulses making it the only governor (electronic) if you want to call it that, but it actually programs the sensors...could that be why they are called programmers, he he? Whether they govern or not....I don't think there are any governors on our trucks (imo)....if so, please tell me where they are at... I'm not laughing at anyone but myself for making it sound confusing, he he. So "where is the governor" that everyone keeps talking about, lol?
Old Nov 27, 2010 | 09:11 PM
plumcrazy73's Avatar
plumcrazy73
can we elect a new governor?
Old Nov 27, 2010 | 10:59 PM
1954Radio's Avatar
1954Radio
He he...ILMAO! Excellent idea, lol!
