High end Wheel spacers
Old Dec 22, 2010 | 07:37 PM
lineman07's Avatar
lineman07
i got the cheep space on my truck and it vibrats badly im trying to order a set fom motorsports tech and they wanna know the center bore dose anyone know what that is and what size my truck is
Old Dec 22, 2010 | 07:52 PM
coolatc's Avatar
coolatc
If you call Motorsport, they have the drawing for the stock Dodge wheels. I did not have to specify what the center bore was since they had it on file.
Hey Bullram, what thickness did you get? Your tires look like they poke out pretty good? I was curious if you went much more that 1/4" did you have to put extended studs in?
Old Jan 15, 2011 | 08:29 PM
coolatc's Avatar
coolatc
After a 3 week wait, my new billet spacers arrived. I installed these today and immediately headed for the interstate. PROBLEM SOLVED. These spacers from Motorsport Technology are very high quality. I put a micrometer on all 4 and could not detect any difference whatsoever in thickness. These are more like 3/8" thick, but I still get plenty of lug nut bite on the studs. They hugged the lugs perfectly and the lip fit inside the stock dodge wheel very tight. In fact when I pulled the wheel back off the studs, the spacer stayed with the wheel.
As far as performance all vibration has been eliminated. This was very much worth the $210 paid.
If anyone needs a 1/4" set of universal spacers I have a set of 4 for Dodge I'll sell cheap.
Old Mar 31, 2015 | 12:17 AM
BigRed10's Avatar
BigRed10
Default help!
Hey guys I am new to the forum. I have a 2010 dodge ram sport that I have had for 5 years now. I just purchased a superlift 4 in suspension lift and some mickey thompson 35 12.5 20 atz p3. I am wondering what would be the proper spacer size to use?
Old Mar 31, 2015 | 05:15 AM
colormeblue's Avatar
colormeblue
Originally Posted by BULLRAM
I put mine between 110---130 ftlbs, started at 75-80 then finished up with 130 ,I checked them last weekend, 1500 miles no movement, mine are there to stay.
I am running 305/55/20's on stock OEM 20"s also
Nice rims you have there!
