largest tire on stock 20s
ive got an '09 Sport QC 4x4.
it sounds as though most people with bigger tires have either raised or dropped the front.
i dont want to lift or lower my truck.
i wanna run the biggest tire (tallest and widest) on my stock 20's with stock suspension.
im thinking 305/50/R20 BFGs. maybe new wheels, too.
any thoughts?
any thoughts?
i read on here that a guy had 305/50's on his truck and they fit with only a little rub at full turn so i ordered a set of 305/55R20 MT Baja ATZ tires. they were delivered this morning. I haven't tried to have them mounted yet and i don't think i'm going to.. i started looking around under there and there is only about a half inch or space between the stock tire and the upper a arm.. the new tires are about 3/4" wider on both sides.. i can't remember who it was that said they have this size but i would like to see how much room he has in that spot. so now i guess i will have to buy new rims or get different tires.. anyone know what offset/backspacing i need to make these tires fit?
I have 275/65R20 BFG AT's and they only rub slightly at full lock to the left on the plastic inner fender no problems otherwise as far as fitment but they killed my mileage probably lost 3mpg due to the heavier weight I am guessing?
Trending Topics
Cpelton - do you get any rubbing??
Also can you post some pix so we can see how they look!! I was thinking about soem BFGs at that size but affraid they would rub
Thx
yes, also odo.
