High end Wheel spacers
Old Dec 17, 2010 | 10:32 AM
coolatc's Avatar
coolatc
Question High end Wheel spacers
Anyone had any experience with Motorsport technologies in CA?
I ordered a hub centric and wheel centric set of 1/4" spacers from them that is bolt pattern specific and it has a lip on the spacer to hang the wheel on assuring everything is true.
I currently have a cheap set of 1/4" universal spacers and am experiencing very slight vibrations at higher speeds. I have had the alignment checked as well as the wheel balance. I am running 305/55/20 on stock Laramie wheels.
The guys at Motorsport explained that these spacers are made of billet aluminum 6061? The spacer also has a custom lip on it depending on what wheel you are running so the wheel can hang on the spacer almost like a hub extention. Sounded like a better mouse trap to me? They were $45 each so I ordered them.
Thoughts?
Old Dec 17, 2010 | 02:49 PM
POWER SEDAN's Avatar
POWER SEDAN
I order all my wheel spacers from Bones Enterprises. They are made of billet aluminum as well. The cost is a bit more, but I've never had an issue with their products.
http://www.bonesenterprises.com/site/
The universal spacers are nothing but junk, and I'm betting your vibration is from the spacers being warped, which is very common, especially if they're not torqued correctly.
Old Dec 17, 2010 | 05:38 PM
coolatc's Avatar
coolatc
I torqued the lug nuts in a cris cross fashion to 80# after I installed the cheap spacers. I checked them about every other day to make sure they were not backing off and so far they have remained tight.
I'm excited how these new spacers will do. What do you torque your lugs to?
Old Dec 18, 2010 | 08:50 AM
POWER SEDAN
I don't have spacers on my Ram (still stock wheels), but my Charger has 3mm spacers though, which are torqued to 105#. I believe the 4th Generation Rams are supposed to be set around 120-130#.
Old Dec 18, 2010 | 09:30 PM
Funkyt's Avatar
Funkyt
I can attest to this. I had some generic spacers (made in china) placed on my truck because of rubbing issues. I had a LARGE amount of wheel shimmy or shake around 55mph. I went back and had them order me a new wheel with a proper offset of 0 because the wheels that were on the truck were a +20mm. Now the truck drives like new since the cheap spacers have been removed.
So if you are using spacers, spend the money and get the ones that will not warp when properly torqued.
Old Dec 21, 2010 | 07:05 AM
BULLRAM's Avatar
BULLRAM
I HAVE THOSE SPACERS FROM THAT COMPANY ON MY TRUCK, they are perfect..the balance is incredible ,no shake no shimmy, and fit EXACTLY, after you remove the lug nuts ,you have to kick the tire pretty hard to get it off of them, (first thing i tried), I put on some loctite also, I got the HUB and WHEEL concentric, very happy with them, 1000 mile check and they are there to stay,
Old Dec 21, 2010 | 07:14 PM
coolatc's Avatar
coolatc
Good to know Bullram, What do you torque your lugs to?
Old Dec 22, 2010 | 06:41 AM
BULLRAM's Avatar
BULLRAM
I put mine between 110---130 ftlbs, started at 75-80 then finished up with 130 ,I checked them last weekend, 1500 miles no movement, mine are there to stay.
I am running 305/55/20's on stock OEM 20"s also
Old Dec 22, 2010 | 12:05 PM
Twist's Avatar
Twist
What center bore did you specify? I need to get a set for the 305/50/20 tires I have.
Old Dec 22, 2010 | 07:29 PM
roberttheall's Avatar
roberttheall
Im also bought from motorsport tech, I got a 2 inch wheel adabter both hub centric and wheel centric. It fits perfect.
