2011 owners!!!!!!!!
Old Dec 30, 2010 | 09:21 PM
canadian dakota's Avatar
canadian dakota
Default 2011 owners!!!!!!!!
i stopped by a dealer ship today that my friend works at to ask question about the ram, i had posted here a while ago about a soft thunk coming from the back end when stopping..
she had recalled seeing some thing that dodge put out as an R.R.T. (rapid response transmission) (IIRC).....
any ways according to my sources.. there was a three hour window in which the factory was either putting not enough, or the wrong fluid in the rear diff. needless to say she has seen two trucks come through with cratered diffs... cause of this. from what shes heard these trucks dont make it past 5000km i encourge all to have this looked at. my ttruck was one of them. a quick search by vin told us the story.
i dont know if it is north of the border only, or both sides but take a look anyways..
Old Dec 30, 2010 | 09:39 PM
CarGuyOhio's Avatar
CarGuyOhio
They issued a recall for this today. Only applies to 11.
They also recalled some 08-11 trucks for a steering issue. It was not a large number of trucks, which seems odd to span 3 years and have a small total number. Must be a unique type of setup.
http://www.wtol.com/Global/story.asp?S=13761125
Old Dec 30, 2010 | 09:41 PM
bryce05's Avatar
bryce05
What size gas tank do you have 26 or 32?
Old Dec 30, 2010 | 10:18 PM
canadian dakota
the article states the recall is expected to begin in February that might be why it was only posted as the RRT when i went in.... or my truck was enough to tip the scales lmao
um 121L so im guessing 32 gal?
Old Dec 30, 2010 | 10:34 PM
Widespread's Avatar
Widespread
I've got the thud and the 32 gallon gas tank. Mine was built in October of 2010.
Where can you find out if your truck i part of the recall?
Old Dec 30, 2010 | 10:38 PM
canadian dakota
i just talked to my friend shes a service advisor she just ran my vin every recall goes by lot no. your vin will have which lot it came from each number stands for something from where it came from to whichoptions are on it
Old Dec 31, 2010 | 09:05 AM
bryce05's Avatar
bryce05
I bet it's no you rear end, I have the same problem with my 2011 sport with the 32 gal gas tank. I get a thud that sound like it's coming from the rear end what it is when you have 1/2 to 3/4 of a tank the gas slams the front of the tank when you stop making it seem like it's your rear end since they removed the baffle in the tank to make it bigger. I would fill up and run the tank all the way down and see if the problem happen threw out the whole tank of fuel. the 32 gal tank is a 26 with no baffle
Old Dec 31, 2010 | 09:11 AM
thedrywallguy's Avatar
thedrywallguy
I got the same recall for low fluid in the rear end, as well I do hear the thump when around 3/4 tank of fuel. These are two separate issues. I had my truck in for the recall and they topped up my rear diff, but still hear the thump which is the fuel hitting the front of the tank when you come to a stop.
Old Dec 31, 2010 | 10:55 AM
canadian dakota
I knownthe tank is a seperate issue but when I asked about she remembered the recall just thought I'd share the recall with everyone
Old Jan 2, 2011 | 01:57 PM
topgun's Avatar
topgun
That recall is only for 4500 and 5500 trucks, hence the low number over multiple years.
22,274 2008-2011 Dodge and Ram 4500 and 5500-series trucks are being recalled to address a problem with the a component of the left outer tie rod that could crack or weaken and cause a loss of steering. Dealers will replace the entire left outer tie rod.
