Heated seats installed!
I put in the Mopar heated seat kit last friday. Just in time too, the temp today is 32. Anyway, it was actually really easy, only took 3 hours start to finish.
http://www.mopar-accessories.com/en-....ashx?id=13990
Once I started, it went so smooth, I could do it again with my eyes closed!
And your 12v accessory outlet still works? I scrolled thru pretty quick, the lack of text leaves a little bit to the imagination. It looks like they give you a plug in splice, so everything still works... correct? I have had heated seats before, and they are something I really really miss. I have to go to the dealership today, I'm going to give them the part # and see how much they are.
I'm looking to get my rear seats heated, do you think this kit would fit in the rear seats. I have a quad cab.
Trending Topics
Honestly for the money, I found some seat heaters that sit over the seat for $19.99ea at a local autoparts store. They plug into the cig lighter so i was going to install them, fish the wires through the carpet up behind the center console. Where I was going to wire them off of the cig lighter wiring behind the console and run them trough some switches. Probably cost about $60 installed. And I'd run male/female plugs in the wiring under the seat so I could take them out in the summer.
