Kenwood Dnx 7360 installed
Old Mar 7, 2011 | 05:58 PM
  #21
72combo's Avatar
72combo
Originally Posted by martinez189
The way I got to the tailgate handle was I removed the bed liner cover and the tailgate cover from inside of the tailgate. I know some people say to remove the tailgate handle before you drill the hole for the camera, well I didn't and pretty much just eyed it and managed to get the hole perfect. Just to let you know that the camera I used was long and just by luck didn’t get in the way of the tailgate handle mechanism. To avoid that I would recommend and night vision camera because they tend to me shorter in length.
both my front and back ccd with leds for night works great, its almost as clear as day,
Old Mar 8, 2011 | 12:40 PM
  #22
martinez189's Avatar
martinez189
Can you post pic's of the location you put the front camera. How does that camera get activated?
Old Mar 8, 2011 | 04:58 PM
  #23
roberttheall's Avatar
roberttheall
Originally Posted by Cdncarnut
"WATCH MOVIES WHILE DRIVING"?
WTF
What are you, insane?
There are enough idiots on the road not paying attention without you adding to that number.
I think he means he has made it possible to watch movies while driving. It is usefull for passengers. Give the guy some credit, why don't ya. Don't just assume he is an idiot. I have a pioneer avic z120-bt, and can also play movies while driving, but that doesn't mean I watch them. LOL...
Old Mar 8, 2011 | 05:01 PM
  #24
roberttheall
Originally Posted by Daniel#88
Any information out there in how to change out the speakers in the dash and doors? I am looking at buying Polk DB351 for the dash and DB651s for the doors.
Yes . here is some information on how to change the speakers in the dash and doors. First remove the door covers, then remove the speakers in each door, next replace with new ones then replace door covers. do the same on the dash. did you really need to ask that.. if you did, maybe you should just go and have a professional do it for you, so you do not screw up your truck.
Old Mar 8, 2011 | 05:10 PM
  #25
roberttheall
Originally Posted by Mimmo Catalano
Guys to make the unit fit in place i had to cut a piece of metal as the MYGIGs are not 2din but a little bit smaller no wire cutting required i used the pac module, everything is plug and play, for the gps antenna as i have the alpine sound i could not use the center grill in the front as there is a speaker inside (as far as i know is empty if no alpine sound) so the gps antenna is in the right side of the dash.
Anybody can pls tell me how to remove the rear handle cover as i would like to move the camera there?
@vulcan03 the unit I replaced was a rer that i moved in my wrangler.
On the inside the bed part of the tailgate there is a cover. you need to remove about 10 - 20 screws to get it off. the you can remove the tailgate handle. I did this and then used a drimmel to cut a hole the right shape and size of my camera , then used epoxy to glue the camera in place. CHECK TO MAKE SURE THE CAMERA IS POSTIONED CORRECTLY before glueing it down in anyway. run the camera cable thru the bottom inside the tailgate then there is a hole going under the truck route the cable along the brake lines with zip ties to the front rubber gromet in the fire wall under the hood then to the radio.. At least that is what I did and it worked out pretty well.
