Brake control for 2011 2500
Old Feb 25, 2011 | 05:01 PM
djf48's Avatar
djf48
Default Brake control for 2011 2500
I just bought a 2011 Dodge 2500 diesel, it didn't come with the brake control that is standard in the 3500s. Can I buy one for my 2500, if so, where can I buy one, what is the part number? Do I have to have the dealer install it? Thanks
Old Feb 25, 2011 | 10:01 PM
HEMI2500TRX4's Avatar
HEMI2500TRX4
You can buy a universal brake controller at any auto parts store. You should have got the wire harness if your truck was ordered with a tow package. Solder and heat shrink your connections and plug in to connection under left side of dash. It is to the left of your obd 2 connector.
Old Feb 26, 2011 | 07:30 PM
djf48's Avatar
djf48
I would really like to buy a stock brake control like the one in 3500. On my 2500, there is just a "cubby" hole where I'm assuming I could put the stock brake control. And the plug-in is right behind it.
Old Feb 26, 2011 | 08:50 PM
sking's Avatar
sking
The factory control does not have enough power for heavy towing. I had to have a prodigy control installed and my factory control is not hooked up anymore. If you check other forums you will find people who tow don't like the factory unit.
