Put in new Sprak Plugs
Old Mar 13, 2011 | 08:31 AM
09 Ram TRX 4 Lover's Avatar
09 Ram TRX 4 Lover
Default Put in new Sprak Plugs
Well it was time for new plugs and it went pretty easy I had done the job before on a 06 ram that I had, so remembered what tools I used. The drivers side was the hardest to do (brake booster) passenger side rear was a little difficult as well. I also went with autolite platinum's.
Old Mar 13, 2011 | 09:47 AM
CarGuyOhio's Avatar
CarGuyOhio
Sit in the engine compartment to do it? That is how I did my 05 and plan to do my 09.
Old Mar 13, 2011 | 12:55 PM
HEMI5150's Avatar
HEMI5150
re: Put in new Sprak Plugs
huhhhh....???? wtf are "sprak plugs"
Old Mar 13, 2011 | 08:18 PM
stlram's Avatar
stlram
Just had mine done at dealership, they had a special for $159.00. I figured at 10 bucks a plug and I dont have to do anything that was a steal.
Old Mar 14, 2011 | 03:16 AM
hounddogg's Avatar
hounddogg
The factory NGK Platiumn plug used in the Durango hybrid and Caliper hybrid with 5.7 which is a 100,000 mile plug can be used. They are a dealer item only so far.
Old Mar 14, 2011 | 04:01 AM
trashman139's Avatar
trashman139
is there only a handful of plugs you can use on a hemi, or can i use aftermarket plugs that give you a bigger spark. just wondering they have so many plugs out there that state they give you a better burn because the way they are shaped.
Old Mar 14, 2011 | 05:51 AM
hounddogg's Avatar
hounddogg
On G.M. vehicles(my vette for one) there is a TSB out about weird electrical things including charge system not operating correctly as well as engine misfire do to wrong spark plugs. It says they think its plugs with PULSE DURATION what ever that is. I think thats what screws with vehicles that have the HEMI.
Old Mar 14, 2011 | 11:22 AM
72combo's Avatar
72combo
Man for 159 I would buy a set for now a a coupon for another set later LOL. So if you use 100,000 mile plugs on a HEMI does it affect the 30,000 mile change schedule? Like I still think you have to change them just as often just because of the fact it is a HEMI?
Old Mar 14, 2011 | 04:40 PM
hounddogg's Avatar
hounddogg
NO. They are 100,000 plug life. You don't change them but every 100k. Same plug used in the Durango and Caliper 5.7 hybrid.
Old Mar 14, 2011 | 05:23 PM
huntergreen's Avatar
huntergreen
any warranty issues caused by using these plugs and extending the change interval? tks
