Center console shifter handle
Old Apr 9, 2011 | 04:30 PM
ArcticWolf's Avatar
ArcticWolf
Default Center console shifter handle
Has anyone replaced there shifter handle on the center console by just removing the handle.
I was looking to upgrade my handle to the new Longhorn handle, but Dodge shows to replaced the handle you have to replace the complete shifter assembly.
Old Apr 9, 2011 | 05:53 PM
turk1270's Avatar
turk1270
i dont know about the longhorn handle but i replaced mine with the chrome t handle from the challenger and all i had to do was replace the handle it took about two minutes the handle is only held on by a set screw i hope this helps
Old Apr 9, 2011 | 10:31 PM
ArcticWolf's Avatar
ArcticWolf
Where's the set screw?
My handle is all one piece with no set screw showing. Do you have to pop the side chrome off to get at the set screw.
Old Apr 10, 2011 | 12:25 PM
Laramie1997's Avatar
Laramie1997
Yes. You have to twist and pull down to pull that chrome cover off to get the screw. As far as I know, it should interchange easily unless dodge did something screwy.
Old Apr 10, 2011 | 01:20 PM
CarGuyOhio's Avatar
CarGuyOhio
In less than 5 minutes you could have this.... Sorry bad quality pic.
Old Apr 10, 2011 | 01:48 PM
ArcticWolf's Avatar
ArcticWolf
Thanks for the info, also nice handle.
Old Apr 10, 2011 | 06:25 PM
turk1270's Avatar
turk1270
Your handle should be two piece put in drive and theset screw should be in front
Old Apr 10, 2011 | 08:28 PM
turk1270's Avatar
turk1270
sorry the set screw is on my thandle you need a std screwdriver to remove the handle.place screwdriver between the chrome piece and the base of the shift **** push the chrome piece down it will seperate then just pull the **** up
Old Apr 10, 2011 | 10:03 PM
War Horse's Avatar
War Horse
I replaced mine with a leather one from a 2010 Challenger. The real leather feels a lot better than the plastic of the stock one, plus the Challenger/Charger (same **** for both models) is smaller so it fits better in your hand and doesn't eat up as much space from the bin next to it.
Old Apr 11, 2011 | 08:19 AM
03vulcan's Avatar
03vulcan
any part numbers for hte Challenger handles either crhomne or leather?
