PLEASE HELP! new wheel & tire shaking?
Old Apr 11, 2011 | 07:31 PM
RumRunner's Avatar
RumRunner
Default PLEASE HELP! new wheel & tire shaking?
Just put 305/45/22 wheels & tires on my 2010 ram. First shop balanced and I couldn't go over 40 and whole truck was shaking very badly. So today had another shop try. Better just a little shake over 55 but very noticible. But now I notice truck seems to be drifting left to right. I might be ok if tires were mudders. But their basic street tread pattern. Please someone what do I need to do to fix this problem. I normally buy a new truck and just run it stock. But this time I thought I'd something different and now I'm kicking myself in the butt.
Old Apr 11, 2011 | 07:36 PM
flashpoint's Avatar
flashpoint
There are a couple of things that could be wrong. First, you may have a bad tire. Some are defected and require alot of extra weight. Unlikely, but I have seen it before. And second, how much weight do they have on your wheels for balance? If it's alot, they can turn the wheel 180 degrees and remount. Then when they re-balance it should take less.
Old Apr 11, 2011 | 08:36 PM
jake09's Avatar
jake09
Sounds like a balance issue still but i would check the front end alignment also. A single tire could be out of round too.
Old Apr 11, 2011 | 11:38 PM
turk1270's Avatar
turk1270
get the tires road forced balanced
Old Apr 12, 2011 | 01:28 PM
Hop's Avatar
Hop
You went to a 22" wheel. Did you happen to check if the wheel is lug centric or hub centic?
Old Apr 12, 2011 | 04:34 PM
jball's Avatar
jball
Remove the brake retaining clips off the wheel studs. The factory wheels are clearanced, aftermarket ones are not. It'll make your wheel not mount flush to the rotor and cause it to wobble.
Old Apr 12, 2011 | 07:18 PM
11RamR/T's Avatar
11RamR/T
Got hub centric rings?
Old Apr 12, 2011 | 08:25 PM
flashpoint's Avatar
flashpoint
Good call on the metal rings, I forgot to mention that one!
Old Apr 13, 2011 | 01:22 AM
FingerBang's Avatar
FingerBang
had the same thing, put in the hub centric rings and the shimmy/shake is all gone.
Old Apr 13, 2011 | 06:06 PM
RumRunner's Avatar
RumRunner
new to all this. Hate to sound stupid but what is hub centric rings and where do I buy them. Also feels like truck sways back & forth. Waiting to get pulled over by po,pos thinking I'm drunk.
