CV Angles
Old Jun 1, 2011 | 12:01 PM
TDTIPMO's Avatar
TDTIPMO
Default CV Angles
I was wondering if anyone could tell me if there is a difference in CV angles between the rough country 4" and 6" lifts. I would think that there would be some difference, but I'm not sure how to find this out. My dilemma is that I'm about to buy a lift and I like the look of the 6" better than the 4", but I know there have been issues with parts wearing out because of the increased angles. I'm putting on 35" Trail Grapplers, so either one would look good, but I like the pictures I've seen of the 6" lifts with 35's. If anyone has any insight, it would be much appreciated.
Thanks!
Josh
Old Jun 1, 2011 | 05:49 PM
cowboys1732's Avatar
cowboys1732
I just put the 4" lift on mine. I think I am correct in saying that all of the actual angles, ie CV, axle, etc are the same as stock with the suspension lift. I know that the axle angles are the same as stock.
Old Jun 3, 2011 | 02:17 AM
TDTIPMO's Avatar
TDTIPMO
Ok cool. So is it safe to assume that it would be the same for the 6" as well?
Old Jun 3, 2011 | 11:24 AM
cowboys1732
Yes sir, I believe so. Everything is higher up, but the actual angles are the same, if that makes sense. That is why I decided to go with a suspension lift. I think I am saying this correctly...someone correct me if I am wrong.
Old Jun 3, 2011 | 11:57 AM
spoon's Avatar
spoon
Not everything is higher up! Remember that you are not lifting your wheels so the CV joints are at a higher angle. That is why people like KORE sell high angle CV joints.
Old Jun 3, 2011 | 01:20 PM
frogslinger's Avatar
frogslinger
I belive with most suspension lifts there is a transfer case drop to maintain CV angles, which is what cowboys meant. I think.
Old Jun 3, 2011 | 04:33 PM
cowboys1732
Thanks frogslinger. My nephew is a mechanic and installed my lift...I was the wrench wench. He was explaining everything to me during installation, so that is where I am getting my "infinite wisdom"
Old Jun 4, 2011 | 03:01 AM
TDTIPMO's Avatar
TDTIPMO
ok cool. Well thanks guys. I'll probably end up going with the 6" and if I have some extra money laying around, I might upgrade my ball joints and cv joints.
Old Jun 8, 2011 | 02:25 PM
FingerBang's Avatar
FingerBang
does anyone know what the stock CV angles are?
im trying to diagnose a wheel shake problem.
alignment is good
wheels are balanced
everything else is tight and good..
shop took a look at the truck and are saying that the right side CV angle is too much and causing the shake i have. if i can measure the angle before i get the dealership involved might save me some headache
Old Jun 9, 2011 | 12:49 PM
cowboys1732
Hey Fingerbang,
Let us know the outcome. I take it this took awhile to develop?
