Old Aug 13, 2015, 08:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Headlight malfunction
Old Aug 17, 2012 | 11:00 AM
  #21
johnl's Avatar
johnl
Same goes for my American friends; but different number.
If you don't complain officially and I don't mean to your dealership; nothing will get done.
Old Jan 6, 2013 | 04:30 PM
  #22
Davidaltman's Avatar
Davidaltman
Same problem here. 2003 1500 Laramie. Passenger side headlight and turn signal won't work when the switch is ln but the turn signal works when it's off. I've replaced the bulbs, the headlight socket, the fcm, and the headlight switch. I'm running out of options here. Any suggestions? Oh yeah and the lamp out light blinks and it chimes (annoying) when it rains.
Old Jan 7, 2015 | 12:15 AM
  #23
Lovett94's Avatar
Lovett94
I need help as well I'm not sure how to follow and find grounds but I was told by a guy it'll cost me 800 to 900 dollars to fix and I'm not try to pay that much the guy didn't even look at it so I really need some help
Old Jan 7, 2015 | 12:41 AM
  #24
HillBillE's Avatar
HillBillE
The OP's solution is posted in his first post (in the quotes) and in post 6.
Seems the lights are tied together even though they are separate bulbs.
At least on the '09's.
Old May 11, 2015 | 08:30 PM
  #25
sunsetrider2011's Avatar
sunsetrider2011
Default Quad light issues
Hey Guys its been a while since ive been on so ive had most things under control today,, Anyways here it is,, 2001 Dodge Ram 3500 sport edition witht he Quad lamp design, my issue is I have my day time hi and low beams working fine but my quad beams will not activate at all, i have power to both my Pink with red strip and green with brown strip as shown in the dia gram but to know avail on the activation on the switch on the column I can ground out the Green with Brwn Stipe and they will activate, so it means its between the swtch and the realy of sorts,, have you guys run into this issueÉ I have though possibly according to the diagram, the high beam indicater isnt working would this be an issue?
The high and low beams work off the signal switch as supposed too,, just cant get the indicator light and the quad beams to light up, Any help would be greatly appreciated .
i should note the indicator light is good as i pulled the dash out and checked
Old Oct 18, 2016 | 05:35 PM
  #26
Mike Haley's Avatar
Mike Haley
I have a 2011 1500 Sport and have been having headlight issues. My high/low/daytime running lights keep failing. Had my bulbs replaced again today, 2nd time in 60 days and the didn't make it 30 minutes. It seems like they went when I went into my underground parking and the "auto on" feature kicked in and turned them on. I know that they worked prior to that as I kept checking them on my way home. Does anyone know why this would be happening or may have experienced the same problem?
Mike
Old Oct 19, 2016 | 09:17 AM
  #27
DodgeCares's Avatar
DodgeCares
Mike
Hi Mike,
Have you had your vehicle serviced at a a dealership to find out why you're having this headlight concern?
Kori
Dodge Social Care Specialist
