Old Aug 13, 2015, 08:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Headlight malfunction
Old Jul 7, 2011 | 07:48 AM
firebug18's Avatar
firebug18
Default Headlight malfunction
Hello, Im not sure if this was discussed yet or not (I didn't see anything when I searched).. I have a 2009 Dodge Ram 1500 and I have been having problems with my passenger side headlight. I have the quad beam light assembly and for some reason the low beam and high beam do not work from time to time. The bulbs are still good and the parking light still works, its just the low and high beam. Just wondering if anyone else has the same problem or knows a fix? I didn't see any technical service bulletins or recalls on it yet and no one else seems to have anything online from what I've seen so far so I'm at a bit of a loss.
Thanks for any information!
update...the fix post #6
Originally Posted by firebug18
Hey All, So I finally had a chance to look at the headlight and bottom line it was a simple grounding issue. A.K.A. the low beam was shorting out and causing a ground short that then caused the piggy backed high beam to not work also (figured this out after about an hour of tracing wires and checking grounds). I changed the bulb and so far so good. If it keeps acting up I will let y'all know. Thanks for the advice!
Last edited by dirtydog; May 10, 2012 at 09:27 AM. Reason: added the fix because people dont know how to read threads entirely
Old Jul 7, 2011 | 08:39 AM
BigBlueEdge's Avatar
BigBlueEdge
Have you taken the headlamp out to examine the wiring harness? The high/low beams are daisy-chained on the harness (or connected together in some fashion) so I could see how they might both be affected if something wasn't plugged together tightly or there was some other issue (water in the connection, damaged wire).
Rob
Old Jul 7, 2011 | 12:14 PM
WNDERR's Avatar
WNDERR
sounds like a ground not working correnctly - unplug any connections you can see, clean, paint a little dielectric grease on there, and put 'em back together
Old Jul 7, 2011 | 01:25 PM
firebug18's Avatar
firebug18
Excellent suggestions.. I had a feeling it has to do with the wiring harness but didnt know where to start. Ill look at it tonight and hopefully thats the problem and its a simple fix. Thanks!
Old Jul 7, 2011 | 09:48 PM
lxman1's Avatar
lxman1
Site Moderator
I am thinking a ground issue too. Let us know what ya find out.
Old Jul 11, 2011 | 07:53 PM
firebug18's Avatar
firebug18
Old Oct 5, 2011 | 08:41 PM
jacruz2's Avatar
jacruz2
@Firebug I'm having the same issue and I would appreciate any info on how you were able to fix this problem seeing how I'm having the exact same issue.
Old Oct 20, 2011 | 05:20 AM
jacruz2's Avatar
jacruz2
Does anyone know if firebug still has a ram? He hasn't logged on for a few months and I'm having this exact same issue and I was wondering what he did to resolve it.
Old Oct 20, 2011 | 11:27 AM
MattsMountain's Avatar
MattsMountain
I just started having the same issue this week. I'm going to go get another bulb to have on stand-by, but sounds like I need to pull it all apart and see what the deal is. Hopefully a quick fix, but I'll report back on what I can figure out as well.
Old Oct 21, 2011 | 07:37 AM
jacruz2's Avatar
jacruz2
@ Matts I think if you have the quad headlight setup and both the low and the high beams are out I think you have more than a bulb issue. Reason being on the quad headlights the low and high are on two separate bulbs. But if you are able to fix the issue I'm all ears.
Thanks
