Bump Feel When Stopping
Old Jul 25, 2011 | 07:47 AM
  #21
BigBlueEdge's Avatar
BigBlueEdge
Originally Posted by vrunner
Its the gas tank. Got the bulletin from the dealer and tested it out. Full tank no bump, 3/4 tank to 1/2 tank, bump, under 1/2 tank it goes away again. Been through 6 tanks and I can almost time it on the gas gauge now. Its especially more noticable if you have the 32 gallon tank.
What's the bulletin from the dealer say?
Rob
Old Jul 25, 2011 | 12:23 PM
  #22
WaySlowWhitey's Avatar
WaySlowWhitey
Gonna have to call BS on that detail from the dealer VRunner. No matter how full/empty my tank is I feel the bump and watch my RPM's drop. Should it be a fuel level issue I would then assume it's starving the pump thus dropping the RPM's. But to your point, under a half tank and it goes away would not support that. I'm still thinking it's a TC issue. Now how do I get my dealer to look into it.
Old Jul 25, 2011 | 01:11 PM
  #23
1954Radio's Avatar
1954Radio
WaySlowWhitey...I like that better than "Laid Back Lenny", lol!
Old Jul 25, 2011 | 07:51 PM
  #24
lxman1's Avatar
lxman1
Site Moderator
Perhaps you are having a different issue than he is. Yours may be a late downshift.
Old Jul 26, 2011 | 01:55 AM
  #25
WNDERR's Avatar
WNDERR
I just got back from a 1,000 ride, pulling a boat ---- and exactly what I found.
When stopping with above 3/4 to a half tank, bumps almost every time. Below a half tank, it goes away. When full, or only down a few (1-6) gallons, it doesn't do it either.
2011 Laramie CC, 34 gal tank.
p.s. Boat weighs about a ton, plus about 850# in the bed, and averaged 15.9 MPG, not exceeding the speed limit.
Old Jul 26, 2011 | 07:49 AM
  #26
BigBlueEdge
Yep, that's the 'gas tank bump'. Seems like it has to do with the larger fuel tank.
There do seem to be several issues that people have going on. The fuel tank one is very obvious once you start looking for it. If someone has another mystery 'bump' and it doesn't correlate to fuel level, or it involves RPM changes, it is something else. I know on our Grand Cherokee with the same Hemi and transmission it had a very rare stop bump that felt like someone hit you from behind. It was way more intense than the fuel tank bump. Seems likely the RAM could be afflicted with the same transmission issue too.
Rob
Old Jul 26, 2011 | 10:35 AM
  #27
svkb's Avatar
svkb
I'm pretty sure that is the issue I'm having. Haven't felt the bump once since the tank was below 1/2. Above 1/2 you could feel it pretty consistantly unless you rolled to a stop gradually.
Old Jul 26, 2011 | 06:37 PM
  #28
hounddogg's Avatar
hounddogg
RRT or TSB link to it?
