Ram Tires
Old Aug 3, 2011 | 07:59 PM
MikeyV311's Avatar
MikeyV311
Default Ram Tires
i have a 2011 Ram 1500 SLT and i use it to snow plow, i already installed a 2.5" leveling kit and a timbren kit on the front end to give me some clearance between the plow frame and road but i still occasionally scrape the plow frame on the road when i hit a bump or try to plow a driveway that has a hill to it. i only need about 2" of clearance and i should be good. i was thinking of putting on nitto terra grappler tires the biggest i can find (325/70R17) and hopefully that will do the trick. my question is do u think this will get the job done and also is that in fact the highest sidewall tire i can put on my stock dodge 17" rims? if anyone knows of a taller tire i can put on my stock rim please let me know, thanks guys.
Old Aug 3, 2011 | 11:56 PM
mdram43's Avatar
mdram43
lotta money to invest to plow, must be making some good money. but anyways, throwing on bigger tires, I dont know much on the 1500's but that seems like an awful lot of tire for just 2.3" of lift in the front. I honestly dont know if those will fit, but someone with a 1500 will tell you. I've got a 2500 leveled and my 34's (actually measure 33 and some change) rubbed the inner fender until i ran a screw to pull it back. But I'm not sure how much height you will actually gain off throwing some bigger tires on there?
Old Aug 4, 2011 | 09:04 AM
RAMULAK's Avatar
RAMULAK
If you're going to go through the trouble of adding taller tires why not just get bigger rims and bigger tires?
Old Aug 4, 2011 | 01:42 PM
The Craig Machine's Avatar
The Craig Machine
I have 2.5" lift up front. I am running 35"s, they don't rub at all. Those might me a little wide though. I have the BFG A/T. I love them and they might be a little better in the snow than the Nitto's. I know the BFGs are a very popular tire and come in pretty much any size. 315/70R17 in the BFGs are about 34.5", and a tad bit narrower than the Nittos. Another option is to go with 20s. Can get the same height with the 285/65R20, (34.7" tall) and have them about 1/2" narrower. Those are the size I have, and no rubbing.....but plan on throwing big bucks down for that combo.
Old Aug 4, 2011 | 09:49 PM
MikeyV311's Avatar
MikeyV311
thanks craig machine, ill either have to try ur suggestion with the bfg's or the 20" rims with bfg's 315/70s
