High Output or non High Output?
Old Aug 14, 2011 | 11:32 PM
milestone's Avatar
milestone
Default High Output or non High Output?
for the Cummins in the Rams, is this a no-brainer decision?
Old Aug 15, 2011 | 07:49 AM
hounddogg's Avatar
hounddogg
Is there a high output and a standard? For years now its just been one. Years ago there was a H.O. and a standard.
Old Aug 15, 2011 | 03:31 PM
we_the_unforgiven's Avatar
we_the_unforgiven
This may be better in the Cummins thread--however I am shopping for a new CTD also and not sure which one I will go with since the H.O.'s are just coming out. A dealer I just talked to said that he could definitely could tell a difference driving the H.O. I am concerned about what kind of economy the H.O. will get versus the regular. Can't get much worse though...
Old Aug 15, 2011 | 03:34 PM
11RamR/T's Avatar
11RamR/T
New PCM w/revised calibration allows the HO 6.7 CTD to reach peak torque @ 1,600 rpm exceeding previous output from 1,200 through 2,800 rpm. Peak HP remains unchanged (350 @ 3,000 rpm), new calibration delivers more than 40 additional horsepower at typical highway speeds.
New higher-rated torque converter improving engine/transmission integration for better towing capability on grades & optimal engine performance.
New crankshaft damper, reduces engine noise and vibration (NVH).
- Class leading 22,700lb max trailer tow weight
- GCWR increased to 30,000lbs
- Legendary CTD reliability/durability backed by an unsurpassed 5yr 160,000km CTD warranty
- CTD equipped Ram's offer class-leading diesel exhaust brake
- Ram is only HD diesel pickup not requiring diesel exhaust fluid
Ram's with the new 800tq CTD get a special "High Output Cummins" badge on the tailgate.
Improved DRW axle w/4.10 gear ratio, new rear-axle pinion, new helical gears, upgraded bearings and a heat-dissipating, finned aluminum differential cover.
As part of the Max Tow upgrade to the Ram 3500, the truck will also get a new engine-mounted, oil-to-coolant transmission cooler to moderate operating temperatures during trailer towing.
Upgraded power steering oil cooler to manage larger loads.
__________________
Old Aug 15, 2011 | 10:18 PM
InterpunX's Avatar
InterpunX
Definately a no brainer after reading that list.
