Old Aug 17, 2015, 01:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Manifold Bolts
Old Sep 6, 2011 | 02:52 PM
mdhouston's Avatar
mdhouston
I was told by dealer that lifetime warrantee doesn't cover it
Old Sep 6, 2011 | 03:23 PM
HammerZ71's Avatar
HammerZ71
I'd fight that, engine manifold = part of the engine = drivetrain!!!
Old Sep 6, 2011 | 04:36 PM
oldjeep's Avatar
oldjeep
You could try, but its an exhaust manifold not an engine manifold and not considered an internal part of the engine.
The powertrain warranty covers the cylinder block and all internal parts of gasoline engines, the transmission case and internal parts of the transmission, plus the drive system and any internal parts that the drive system relies on. The warranty will cover parts and labor costs needed to repair any of these items should they fail.
Old Sep 6, 2011 | 05:37 PM
mike2810's Avatar
mike2810
From my 09 warranty book under lifetime warranty, exhaust manifolds is listed as a covered part.
since it is, would think the bolts would be also.
E. Parts Covered
The Lifetime Powertrain Limited Warranty covers
these parts and components of your vehicle's
powertrain supplied by Chrysler Motors LLC:
Gasoline Engine:
parts; cylinder head assemblies; timing case, timing
chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake
and exhaust manifolds; flywheel with starter ring
gear; core plugs; valve covers; oil pan; turbocharger
housing and internal parts; turbocharger wastegate
actuator; supercharger; serpentine belt tensioner;
seals and gaskets for listed components only.
Old Sep 6, 2011 | 06:00 PM
oldjeep's Avatar
oldjeep
E. Parts Covered
Gasoline Engine:
Should be then, that is different than the text I found online.
Old Sep 6, 2011 | 07:31 PM
brettj2408's Avatar
brettj2408
pedro dog... the dealer ship replaces the manifold gaskets if the bolts are broken. and also the manifolds if they are warped. but when it came out as an rrt and the bolts were not broken we just replaced the bolts kinda like preventive maintence in a way
Old Sep 6, 2011 | 07:32 PM
HEMI_ROM's Avatar
HEMI_ROM
Originally Posted by brettj2408
Lifetime powertrain if first owner and I'd your manifold is warped they should replace that too
Correct, the exhaust manifold warps and of course you loose the gasket, all because of a cheap bolt. Scariest part is haveing to pull the head to remove a broken bolt. It Absolutely *is* covered under the lifetime warranty, I have all the receipts to prove it. I would hate to think what all that would have cost W/O a warranty
Old Sep 6, 2011 | 08:18 PM
Pedro Dog's Avatar
Pedro Dog
I was thinking that since it is an RRT, they will not always replace the bolts unless the owner complains about the noise that others have described as a tick, "cricket", noisy lifter, etc, etc. To me by the time it's making noise, its already leaking and doing some damage to the gasket. In my case, the dealer did replace the 4 bolts when I was in the shop the last time without me even asking for it - I wasn't hearing any leaks.
If they are replacing the gasket when the bolts are broken, then good for them!
Old Sep 6, 2011 | 08:31 PM
kddsRam's Avatar
kddsRam
Ya, the lifetime powertrain warranty is pretty inclusive and fair. One dealer I spoke to tried telling me "if oil touches it, its covered.". That made me look in the manual and I found the details as noted in Mike's post. This is a covered repair if you have the powertrain warranty.
Old Sep 6, 2011 | 08:52 PM
evan4434's Avatar
evan4434
Does anyone know the part numbers on these bolts, so I can replace them as PM since I am a second owner. I sure as heck don't want to have to pay to have the head removed in the future if a bolt breaks off!
