oil plug size/headlight bulbs
Old Oct 15, 2011 | 10:05 AM
T Man's Avatar
T Man
Default oil plug size/headlight bulbs
I am not having much luck with the search engine. I just got a 2011 Ram 1500 4x4 Big Horn hemi, what is the oil plug bolt size? Also, I have two low beam bulbs and two high beam bulbs, which ones do I need to switch to the brighter silver star ones? Thanks.
Old Oct 17, 2011 | 09:35 PM
Mikeyyy816's Avatar
Mikeyyy816
I don't know the bolt size off hand...but climb underneath and bring a few sockets.....
Go with HID's worth the $$$, silverstars are good not much of an improvement..try adjusting your headlights by five turns on the headlight adjuster under the hood. It'll make a big difference even w/ stock (crap) bulbs...
Old Oct 21, 2011 | 12:10 PM
T Man's Avatar
T Man
Ok thanks, turns out my oil plug is 1/2 inch. I am not sure where the headlight adjustment is under the hood but I'll look.
Know of anywhere I can order the HID bulbs? I have the four bulb setup, do I just change the lowbeam bulbs or the highbeam too? Do I need to remove the whole lens to change the bulbs? (I have been told by some you need to and others you don't)
Old Nov 11, 2011 | 03:19 PM
Mikeyyy816's Avatar
Mikeyyy816
Hey sorry about the delayed response! But the adjustment screw is on the side just forward of the wheel well under the hood and you'll see a hole w/ an arrow pointing towards it and there's a screw under there. (it's a torx bit screw T-20/25 if I remember together)
For HID's I am running a projectors w/ mine... but as of HID's I am using Retro-Solutions 55w 6k Bulbs in my high beams and in my fog lights. I have a thread w/ my headlights...I only changed my low beams and foglights to HID's... there is no need for highs w/ these puppies! If you check out my post below you'll see some night shots!
https://dodgeforum.com/forum/4th-gen...-new-pics.html
Old Jan 15, 2012 | 01:43 PM
Dusty48's Avatar
Dusty48
The drain plug is a 13mm.
