View Poll Results: Star Case - Transmission Issue, moan, drone, rattle issues
Noticed this issue but not worried about it
0
0%
Multiple Choice Poll. Voters: 30. You may not vote on this poll
Star Case - Transmission noise - For those that are still looking for this info
Thank You...! I agree...!
I do not agree with you. The reason I had my original TC replaced was because of a shudder that could be heard and felt. It occurred at constant speed of about 38 to 42 and during a slight incline such as an overpass.
If you are in tune with your vehicle and it feels like mine felt you know the difference between MDS and a TC issue.
1. I have dual exhaust anyway
2. I already had it replaced with new and improved TC because of shudder AND noise
3. The buzzing occurs when MDS is disabled by programmer too so it cannot be that in my case. I know the feeling and sound of MDS.
Personally, i think you`ve done some mods to your truck and that may be the whole reason why your`re having problems.
Originally Posted by Dusty48;
. I have experienced vibration related to road speed with the 20-inch Wranglers and there is a technical bulletin on this issue. This vibration is present even when the transmission is moved into neutral. The speed at which this occurs has varied, although my tires are scalloped so bad now it's present at all speeds over 60
As of yet there is no TSB.
There is a Star Case... https://dodgeforum.com/forum/attachm...1-37-20-am.jpg
Basically special instructions to dealers on how to treat a certain complaint.
I printed the photo, took in my truck and asked them to test for this, they have ordered the new torque converter, should be in soon.
SERVICE BULLETIN
NUMBER: 22-001-10
GROUP: Wheels/Tires
DATE: April 08, 2010
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 22-001-09, DATED MARCH 7, 2009, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE THE ADDITION OF VEHICLE MODEL YEARS.
SUBJECT:
Vehicle Vibration or Shake at Highway Speed
OVERVIEW:
This bulletin provides information to diagnose vehicle vibration concerns at or during PDI or if the vehicle is stored for a length of time prior to delivery.
MODELS:
2009 - **2010** (DS) Ram Truck (1500)
DISCUSSION:
Tires used on the 1500 Ram models can develop a temporary flat spot when sitting on the lots and or while being shipped. This condition is more prevalent on 4 x 4 models with 20" tires and wheels due to the additional weight on the front tires from the unique components (i.e., front axle and transfer case). Weather is a critical factor and temperatures significantly above and below normal temperatures can temporarily "flat spot" tires when vehicles are shipped by car hauler or rail or if vehicles are stored for an extended period. The vibration may be felt in the steering wheel and / or seat, and may be most noticeablr at highway speeds, 60 MPH (96 kph). This may be misinterpreted as an out of balance tire.
DIAGNOIS:
If the tires are flat-spotted due to shipping or sitting in the lot for an extended period, the vehicle vibration will go away after the tires are warmed up, (normally 10 to 20 miles of highway driving depending on outside temperatures).
REPAIR PROCEDURE:
1. Road test vehicle 10 to 20 miles to allow the tires to obtain operating temperature.
2. If highway driving doesn't resolve the vehicle vibration, follow the procedures outlined on DearCONNECT>TechCONNECT>Group 22 - Tires and Wheels.
NOTE: Replacing tires should only be done as a last resort after all appropriate wheel and tire diagnostics have been completed. U.S. dealers can contact the MOPAR tire program at 1-866-877-TIRE (8473) if assistance is needed with obtaining a tire. Canadian dealers can contact the MOPAR tire program at 1-866-529-8473 if assistance is needed with obtaining any tire.
******end of bulletin***
Needless to say this did not really address my problem since when this issue arose I already had better than 15,000 miles on the vehicle. However, after talking to a number of owners and service people I've come to suspect the clue is in step 2 of the repair procedure. If this truly could never be anything other than a "temporary" condition resolved by warming up the tires, there wouldn't be a need to replace a tire. There's a fair amount of opinion that the problem is the Wrangler 20 inch tires are prone to flat spot, and that's followed-up by evidence from owners who have switched to another tire make and had the problem completely disappear.
Regards,
Dusty
What tires are you running now(?)
New tires aren`t properly balanced...? Possible bad shock...?
Were the wheels checked for out of roundness when new tires were put on...?
Dusty
Big thanks for adding the TSB, this will hopefully help others.
My truck had this very issue, tires fixed that problem per TSB bulletin.
LU229 I'm running Hankook DynaPro ATMR10's (stock size) on Monster XD Addict 20x9 wheels. Had a bad shake at 70+ mph and had the tires rebalanced. No joy. 2 additional balances later and Discount replaced the tires. I still have a shake but not as bad. That said, I still also have the partial throttle rattle. As I said, it's not the tires.
This is my 3rd Dodge P/U and 4th Chrysler vehicle and I've gotta say, they didn't do a very good job on the 4th gen. Atleast not on my 2011.
As for your throttle rattle, what do you think it is....
The torque convertor issue, or the MDS vibe/rattle issue...???
Couple of us are working on developing a "bolt on ballast" for the MDS rattle,(to absorb the vibes created by being in MDS mode) we`re still in the testing phase right now. We`re close with defeating the MDS rattle with a ballast, and continuing to improve on the ballast design. If we get this ballast to work, we will be letting people know about it. I suspect by summertime, we`ll have it working very well.
Just gotta keep up the good fight.
