need info on tightening front axle nuts on 4x4.
Old Jan 24, 2012 | 10:25 PM
rolltidehemi's Avatar
rolltidehemi
Originally Posted by LU229
Instead of starting a pizzin contest between other members on how or what to do, why dont you call the company you bought your kit from. I dont want to sound harsh and i`m not trying to be, but posts like this just start a war on how everybody else would do it. All you will likey find on here, are people with opinions that think they know best. Do it the right way, call the company and get the correct spec`s and percedure.
LoL!!! Yeah I called before I asked for "information", come on really? Guess what, they don't know, stated: "tighten to factory specs", figured I could get a dodge tech to pass some information on, Lu you seem just as happy in these pissing contests, those ideas I already know about, and to me are not proper or accurate (IMHO, useful when its all you have) when you can get the spec info you need somewhere instead of guess, just MHO, thanks for the ideas and infornation guys, and yes all opinions appreciated, welcomed, and respected, pissing contest no, healthy debate yes, what our society is founded on, so if someone has the manual (online one is down) or a tech can give me accurate info, thanks in advance, if it's 140 ft/lbs then thank you very much, any ideas/opinions I'll take them, too! Have an awesome day, ohhhh and I hope I don't sound harsh! LoL :-)
:icon_be amme:
Old Jan 25, 2012 | 01:53 AM
LU229's Avatar
LU229
:icon_be amme:
rotflmao.... i have to agree with you.... heheheheheeee, oop`s sorry, too harsh again...lol.
The torque is still 140ftlbs bro, have a good one
Old Jan 26, 2012 | 02:39 PM
Spdbird's Avatar
Spdbird
Default torque specs
INSTALLATION
1.Install half shaft on axle shaft. Push inner C/V (1) firmly to engage axle shaft snap ring into the inner C/V housing.
2.Clean hub bearing bore, hub bearing mating surface and half shaft splines.3.Apply a light coating of grease to the front axle shaft output splines.4.Install half shaft (2) into the knuckle.
5.Install steering knuckle (1).6.Install brake rotor and caliper
7.Install half shaft hub nut (1) and tighten to 251 N·m (185 ft. lbs.).
From 2009 service/maint manual
Old Jan 26, 2012 | 03:24 PM
rolltidehemi
Originally Posted by Spdbird
INSTALLATION
You rock, I knew someone would get the right info, Thanks brother!
:icon_bee rchug::i con_pala:
No disputing that.
Spdbird is there anyway you can scan and send me a copy of the pages? PM me and I'll send you my email, Thanks again, was getting ready to do this next week on my off week.
Old Jan 26, 2012 | 06:58 PM
Owensue's Avatar
Owensue
185 sure is a long way off from 140
One could have determined this HUGE difference using the proposed 'test' method.
Good thing someone else chimed in or it may have come apart on you.
Old Jan 27, 2012 | 12:21 AM
LU229's Avatar
LU229
oop`s, i`m sorry, i was thinkin "wheel nut" torque, (wheel nut torque IS somewhere around 135 to 140ftlbs) so go ahead and bash me, my bad. Ok, so i fugged up, i`ll just stick to reading the forums and leave all this really hi-tech stuff to YOU guys from now on.
The ole`man is headed out to the pasture for good......Ba byeeeeeeeeeee
Old Jan 27, 2012 | 07:46 AM
rolltidehemi
Shiz happens Lu, we all slip on stuff, you definitely haven't cornered the market, that's why it's good to converse/debate thanks for your input and again nothing has to turn into a pizzin contest, unless there is thin skin and egos involed.
