2012 ram 1500 rear suspension upgrade?
Old Jan 24, 2012 | 09:36 PM
jetmech_25's Avatar
jetmech_25
Default 2012 ram 1500 rear suspension upgrade?
As expected with a 1500, I have serious sag when towing my RV. Here's my setup:
In the bed, I have a kids quad and my dirtbike (about 380 lbs)
On the hitch, the RV (700 lb tongue weight with load-distributing hitch)
My truck is rated for 1625 lb load capacity, so its within limits, but the rear sags alot. Since Add-a-Leaf isn't an option, has anyone added air bag systems or stiffer springs? Interested in your thoughts on either, prices, etc.
Old Jan 24, 2012 | 10:39 PM
HammerZ71's Avatar
HammerZ71
Bag it. I have good, old fashioned leafs and I use air bags. I won't run Add-a-Leafs even though I can as they are just too damn stiff when not hauling or towing, but bags can be adjusted for load so they ride nice when not needed...
Old Jan 24, 2012 | 11:55 PM
jayman84's Avatar
jayman84
I started off with firestone airbags and they didn't survive my first winter. They got brittle and broke. I then tried the airlift brand bags and they are holding up a lot better this winter and they work wonders. Check around online and you should be able to get a set for under $100.
Old Jan 25, 2012 | 01:12 AM
jetmech_25's Avatar
jetmech_25
Just ordered the Air-Lift kit for $87 shipped. We shall see! Thanks for the help!
Old Jan 25, 2012 | 09:12 AM
DGjohn3's Avatar
DGjohn3
I'd either go with some Air Bags or a Timbren Kit, both will do the trick for you. www.sdtrucksprings.com has a lot of options for helper springs at a great price.
Old Jan 25, 2012 | 09:03 PM
WESIDE's Avatar
WESIDE
Any links to that air lift bags website? looks like a pretty reasonable price. Are they so called "plug and play" or is there additional parts needed. I will be towing in the near future and dont want to hassle with *** end sag when that time comes. THX
Old Jan 25, 2012 | 09:51 PM
jayman84's Avatar
jayman84
The airlift kit will come with everything you will need to install them. The most difficult part is getting them compressed and shoved into the coils but it is worth the hassle.
Old Jan 27, 2012 | 11:43 PM
jetmech_25's Avatar
jetmech_25
The price I quoted was just for the bags with hoses. There are all kinds of kits from just a T-fitting so they air up evenly to a full kit that has an onboard compressor to adjust each bag independently on the fly. The price goes up fast when adding options.
Old Jan 28, 2012 | 02:32 PM
cpelton's Avatar
cpelton
I would hook them up so you air them up independently, without the T fitting
