Tow Rating
Old Mar 1, 2012 | 05:03 PM
blyttle72's Avatar
blyttle72
Default Tow Rating
Looking at a purchasing a new 4x4 crew cab 2012 dodge ram express with the 5.7 liter.
The tow rating for the ram express is 2000lbs less than on other trims of the Ram.
I would like to have the 10,000 lb rating and I was confused as to why the Express tow rating is so much lower.
Does anyone know why?
thanks
Brian
Old Mar 1, 2012 | 05:08 PM
Ironsides's Avatar
Ironsides
What gear ratio does it have in the differentials?
Old Mar 1, 2012 | 11:10 PM
keen's Avatar
keen
According to:
http://m.ramtrucks.com/shared/pdf/20..._Tow_Chart.pdf
the 5.7 4x4 crew express (and ST) is rated for 8,500 with the 3.55 rear end, 10,000 with the 3.92 - if you're comparing trucks on the lot, that's likely why.
You can usually use the tow rating and GCWR chart to back track to figure out what rear end a truck has when you're looking at it when it's not on the window sticker.
Note that from a legal & DOT standpoint, you can't just swap out the rear end and get the higher GCWR - they enforce (when they enforce...) what's on the mfr sticker, fwiw.
Old Mar 1, 2012 | 11:13 PM
keen's Avatar
keen
oh, and those ratings only apply to gooseneck or 5th wheel hitches, or with the use of a weight distributing receiver hitch - w/o a WD setup it's 5,000 across the board.
