To everyone with a Procomp 6" lift
Old Mar 13, 2012 | 09:30 PM
big4x4dodge09's Avatar
big4x4dodge09
Originally Posted by InterpunX
Ok thanks. Does your blocks where the springs sit lean back a bit, like in my last photo you can see the blocks are not quite parallel to the frame. And do you have the rings that ridem high was talking about.
as soon as i get back from the field on thursday, ill snap a few pictures and check it out for ya
Old Mar 13, 2012 | 10:07 PM
InterpunX's Avatar
InterpunX
Thanks man
Old Mar 14, 2012 | 06:56 PM
InterpunX's Avatar
InterpunX
Just found a picture with those ring spacers on another site, looks like i don't have them. Probably to make the truck more level they didn't install them but whatever i guess. Still wouldn't help the axle leaning back.
Old Mar 16, 2012 | 12:10 PM
iskybantilus's Avatar
iskybantilus
is it possible that the spacer bolted to your axle (whatever that is called) has a left and right version that are at angles to correct that alignment, and yours are installed on the wrong sides? or is it perfectly flat?
just looking at pictures and thinking of possibilities. I agree it looks like "spacers" are just washers used to lift back up to suit preferences.
