Spark plugs
installed the autolite Irdiums last night with 100,000 kms on my truck. Pretty painless, I had installed the OEM plugs at 50,000 kms so I learnt a trick or two from the last time. I also put in a Poweraid throttle body spacer in too while I had my intake off.
Just changed my plugs in my 2009 1500 Laramie at 30,418K miles. Was certainly a challenge, but with an assortment of extensions the job went pretty good. Patience, persistence, and not minding laying across the engine on your belly are requirements for this job. Used the OEM NGK plugs w/o anti seize. Took about 1.5 hours. Got the plugs at local dealer for $72. My ribs are a little sore but worth saving over $200.
Here's what you want.
Will be replacing my 2nd set of stock copper ones in about 5K... oh hells yeah!! Just what I need between my Intake/bored throttle body and Headers/Exhaust.
http://www.pulstar.com/products.htm
http://www.autoaccessoriesgarage.com...es-Spark-Plugs
^^^Set of 16^^^
[youtube]2lezmp_rpro[/youtube]
[youtube]DykHkPV73JY[/youtube]
^^^Set of 16^^^
