Another 115V outlet question
Old 10-17-2012 | 10:40 PM
klpi2010's Avatar
klpi2010
Hi Everyone,
This is my first post on here. I have a related question I would like to ask all of you. It's not for a Ram though; It's for a 1st Gen Durango. Hope it's ok as I am a little unsure of the rules.
I have a 4 gauge power wire running to the factory storage bin behind the 2nd row seats (I don't have a 3rd row seat). In that compartment, I have 2 car amplifiers running a total of 1100 watts rms (95 amps). I am planning to install a small power inverter (400 watts continuous) to bring that total to 1500 watts (145 amps).
I have a 100 amp fuse currently off the 4 gauge wire near the battery and planning to change that to 200 amp fuse that I had. I am also going to use a power distribution block to split to the amps and inverter. Also, I am routing a separate 4 gauge wire for the ground on the inverter.
Anyway, my questions are:
Will the existing 4 gauge wire be safe enough to run the small inverter with the amps?
Should I run a separate power wire for the inverter?
Are there any other things I should take into consideration?
I do get the lights slightly dimming when bass hits when I totally turn up the radio loud as well.
The alternator is 136 amps and all power and ground from factory is still original but in great shape.
I also have some additional driving lights attached to my grill guard on a separate switch (I forget the wattage).
Any input you can give me would be awesome!
Quick Reply: Another 115V outlet question
