check engine light
Old Apr 25, 2012 | 07:48 AM
tbeck's Avatar
tbeck
Default check engine light
Hey, I'm new to this forum but I have a question. My 2011 2500 Longhorn diesel had the engine light come on. When I ran the code it came up as P24A0 Unknown code. Have you heard of that one?
Old Apr 25, 2012 | 09:26 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
im moving your post to the 4th generation ram section since that is what you have, this is the durango section and we cant help you out with that here.
Old Apr 25, 2012 | 10:52 AM
DodgeCares's Avatar
DodgeCares
TBeck,
Welcome to the forum.
The P24A0 may be the exhaust temp sensor getting a reading that is out of range or the sensor itself may be bad. Would suggest having the dealer check it out for you.
Old Apr 25, 2012 | 10:57 AM
LU229's Avatar
LU229
Delete the gov/epa, problem solved...!
Old Apr 25, 2012 | 06:10 PM
Pedro Dog's Avatar
Pedro Dog
P24A0 CLOSED LOOP DPF REGENERATIION CONTROL AT LIMIT – TEMPERATURE TOO LOW
The truck is attempting to regen, and the temperature at the front temp probe isn't high as it needs it to be to properly burn out the DPF.
