Leaking Washer Fluid Sensor
Old Jul 22, 2012 | 03:52 PM
Dr. Bill's Avatar
Dr. Bill
Default Leaking Washer Fluid Sensor
Spotted a bad leak under my truck yesterday. It is coming from the washer fluid tank. I pulled the grille and the tank, leak is from the grommet that seals the sensor. RRT 09-010 was performed on March 18, 2009. What's up with these dang tanks leaking and is there another fix in the works? Another tread mentioned RRT 09-045, but I don't have any info and that one. Any help appreciated. Truck is 09 Sport 1500, build date 8-08.
Old Jul 24, 2012 | 10:26 AM
Dr. Bill's Avatar
Dr. Bill
Dealer says that items repaired under RRTs are covered for 12 months. Since my "repair" has exceeded that, they can't help me. They will sell me the part for $12.96. If it is the same poor design/materials, I guess that I get to do this every 3 years, LOL.
Old Jul 24, 2012 | 05:06 PM
Dr. Bill's Avatar
Dr. Bill
Good and Bad news. The leak was actually the pump motor leaking at a vent or weep hole. It is on the back of the motor and was seeping onto the grommet. I guess a diaphragm or something failed in the pump assembly. Either way, appears to be fixed. Sad that a pump would only last 3 years, be looking for this problem if you see a leak of washer fluid.
Old Jul 25, 2012 | 09:48 AM
LU229's Avatar
LU229
So did you replace the pump...??? And how much did it cost you...???
Old Jul 25, 2012 | 11:51 PM
capsfloyd's Avatar
capsfloyd
Did you buy the Max care warranty ??
Old Jul 26, 2012 | 01:20 PM
Dr. Bill's Avatar
Dr. Bill
I replaced the pump with another OEM. The first one that came on the truck was a VDO and the new one is from CZ and a different brand. The universal pumps at auto parts stores would not work, at all. List was $63 for the pump and $12 for the grommet. It appears to be fixed. I have the lifetime power train warranty, but the factory warranty ran out at 36K and I have 38K miles. I could have pressed the dealer to contact Mopar and get it covered, but I would have had to put it all back together for them to take apart so I simply did it myself.
