Another leveling vibration issue...
Old Aug 27, 2012 | 02:01 PM
JamesRam's Avatar
JamesRam
Default Another leveling vibration issue...
So I installed the Bilstein 5100 leveling struts and rear shocks on my 11 ST crew cab 4x4 yesterday and I have noticed a vibration while accelerating in 4x4 on pavement. My truck is going to get a wheel alignment later today, so hopefully that solves my problem. If not, what other options do I have to try and iliminate this vibration?
Old Aug 27, 2012 | 02:17 PM
oldjeep's Avatar
oldjeep
Why are you running in 4x4 on pavement? I'd expect a lot worse than vibration if you do that much.
Old Aug 27, 2012 | 02:20 PM
JamesRam's Avatar
JamesRam
I've read a lot online about people having vibration problems in 4x4 after installing a leveling kit on the 4th gen rams. I rarely use the 4x4 on my truck but I stuck it in 4x4 this morning to see if I have the issue and I do.
Old Aug 27, 2012 | 07:27 PM
JamesRam's Avatar
JamesRam
Alignment is done and the problem still persists.
Old Aug 27, 2012 | 07:52 PM
Mikeyyy816's Avatar
Mikeyyy816
Well you have the vibrations due to the excess angle on your CV joints...if you don't want the vibrations take them off.
Don't put your truck in 4x4 on dry pavement...
I have my truck w/ the bilsteins and if I use it on a dirt road I can't tell if I have the vibes...I put it in 4x4 on wet grass before and found out I had the vibes.
Old Aug 27, 2012 | 09:32 PM
rdculus's Avatar
rdculus
Would a set of high angle cv joints fix this? I've been thinking of levelling mine but i drive in 4x4 on pavement a lot I wouldn't like bad vibes from the level kit.
Old Aug 28, 2012 | 12:12 PM
Mikeyyy816's Avatar
Mikeyyy816
JayMan did the high angle cv's on his truck and I believe he still had this issue... If he see's this thread I'm sure he'll jump in..
Old Aug 29, 2012 | 11:25 PM
JamesRam's Avatar
JamesRam
Yeah I've been reading on forums about people purchasing the high angle cv joints and the joints not changing anything. I believe I will be calling Bilstein tomorrow about returning the full set and then removing them from my truck this weekend.
Old Aug 29, 2012 | 11:43 PM
LU229's Avatar
LU229
Smartest move you can make at this point...!
Leave it stock, you`ll have no problems.
Old Sep 2, 2012 | 09:28 PM
Mikeyyy816's Avatar
Mikeyyy816
if you knew about these vibrations and were so concerned about them why did you bother installing them?!? did bilstein say they'd take them back? i'd be suprised if they do since you installed them...they have lifetime warranty but I don't know about returning them bc you "dont like them"....did you keep your old struts and get them off without ruining the strut rod? I ****ed up my strut rod pretty bad on my driver side when doing mine.
