Old Aug 13, 2015, 06:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Remote start... Not working
Old Dec 10, 2019 | 01:50 AM
Roush109's Avatar
Roush109
Originally Posted by adam204
All these have been met...
- shift lever in PARK
- doors closed
- hood closed
- HAZARD switch off
- BRAKE switch inactive (brake pedal not pressed)
- ignition key removed from ignition switch
- battery at an acceptable charge level
- Remote Keyless Entry PANIC button not pressed
- fuel meets minimum requirement.
It is a Factory remote start.
I think there is a bigger problem here there Remote start...
Put my truck into park today and
- Service Trailer brake light came on
- ESP 4WD came on
- the Traction control light turned on
It's going in on Friday to dealer
My truck did the same thing, I replaced the brake switch by the brake pedal and it solved everything. It cost about $40
Old Feb 28, 2020 | 09:41 PM
Nunya Business's Avatar
Nunya Business
Originally Posted by Roush109
what ended up being the cause of this? I have a 2011 ram and it's doing the same thing
What was the cause my 2013 Dodge Durango is having this issue
Old Feb 28, 2020 | 10:04 PM
Roush109's Avatar
Roush109
For my truck it ended up being just the brake switch by the brake pedal. A $40 part that just clips into place, I couldn't believe that small part affected so many things
Old Feb 16, 2021 | 10:17 AM
Keith Broughton's Avatar
Keith Broughton
I was having issues with my remote start not working. Tried all of the suggestions I found, nothing worked. I eventually took the battery out of the remote and left it out overnight. The remote start has worked perfect after that.
