annoying noise at highway speed
Old Dec 12, 2012 | 07:02 PM
phil44's Avatar
phil44
Default annoying noise at highway speed
Hi
I have a noise at above 80km/h, it sounds like something is loose, its a rattle or maybe something caught on the underneath flapping in the wind, I have checked the obvious this like the mirror, but cannot find anything loose, I have even reached out and folded the mirror in but the noise stays the same.
Has anyone else had this problem or have any sugestions where to look.
Phil
Old Dec 13, 2012 | 02:09 AM
LVRR's Avatar
LVRR
I know you said it sounds like it is outside, but the passenger side seat belt if not hanging properly will give you that type of noise, a tapping noise at higher speed or going over rougher roads. It taps against the pillar.
Old Dec 13, 2012 | 10:33 AM
Dale_K's Avatar
Dale_K
I had a leaf wedge between the cab and bed behind the driver's door and it made a bad noise. Somehow the leaf was stuck good enough to not blow away but still loose enough to flap like crazy.
Old Dec 13, 2012 | 12:38 PM
Atomic Dog's Avatar
Atomic Dog
Do you have a jack-in-the-box head on your antenna by any chance?
Old Dec 13, 2012 | 12:41 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
A 3" piece of masking tape in just the right spot and I could drive you to insanity.
Old Dec 13, 2012 | 12:43 PM
Dustinmc15's Avatar
Dustinmc15
Check the front wheel well liners, in high speed/windy situations they would bend back into the tire and make that kind of noise on my truck.
Old Dec 13, 2012 | 06:48 PM
phil44's Avatar
phil44
Thanks for the replies, nope nothing on the antenna. I was looking again and saw leafs behind the cab so cleaned them out but the noise is still there, I also noticed that maybe the rubber around the windshield could be causing it, has anyone had any trouble like this when the temp is cold because I think when it got colder here is when the noise started. Also I will have another look at the wheel well liners
Old Dec 20, 2012 | 11:47 PM
devile's Avatar
devile
I've heard the noise for the past two winters... it goes away in teh summer and i forget to look for it. I've had my windshield replaced, with an updated seal, changed my wipers, taken off wheel well liners (only for a day) to try and find the noise. I gave up and turned up the radio ... It almost sounds like someone typing on a telegraph, a clicking sound, definitely hard to explain, but I bet it's the same. STRANGE!
Old Dec 21, 2012 | 07:46 PM
phil44's Avatar
phil44
Yes that sounds like the noise, I was thinking maybe it is something inside the mirror
Old Dec 22, 2012 | 12:01 PM
hemiquad4x4's Avatar
hemiquad4x4
I have what sounds like the same noise that just started with the cooler temps. Mines definitely the seal on the windshield right above the mirror. I can push on the windshield and the noise changes. Its only when I'm going 65 to 70 mph and the windows are all rolled up though. When I crack a window it goes away. And its really loud!
