Old Aug 17, 2015, 12:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
Hi and TIPM Relay Question
Old Apr 8, 2013 | 09:54 PM
dodge29's Avatar
dodge29
New Member
Default Hi and TIPM Relay Question
Hello Everyone!
I have a 2011 crew cab Ram ST with 5.7 liter hemi. I'm trying to identify some of the fuses in the top half of the TIPM, specifically K1, K2, K3 and K4. I can see how they are labelled in the lid of the fuse cover. What I'm intersted in is how they effect the trucks starting, if they are bad, especially K3. Picture attached.
Old Apr 9, 2013 | 01:11 AM
Owensue's Avatar
Owensue
K's are relays, not fuses.
Explain your situation in a little more detail and I am sure you'll get some informative responses.
Is it turning over? Do the gauges light up? Are you trying to Hotwire a truck?
LoL, just explain a little more for the best help.
Old Apr 9, 2013 | 08:38 AM
dodge29's Avatar
dodge29
New Member
The truck was having an intermittent starting issue until 1 week ago today. It had been back to the dealership 4 times with no help. One week ago today I opend the fuse box lid and found several of the grey relays that were not seated all the way.
Others have told me that there is an additional relay that is an integrated part of the TIPM itself, which is down underneath the fuse box. They did not explain the relays I am questioning and stopped responding. It seems like Chrysler might have a group out crusing these forums to run damage control. They will answer questions to a point, then they disappear. My point is that any relay tagged with a "run" as part of its name, or "start' as part of it's name, probably has something to do with starting and running the vehicle.
Also, I'd welcome any comments on the MDS system of the Hemi engines, the harmonic stress it puts on the timing chain and tensioner when the cylinders activate, and the resulting catastrophic engine failures they have been experiencing as a result of timing chain/tensioner failures. This is happening in both Challenger and Ram vehicles.
Ok how was that?
Old Apr 9, 2013 | 03:17 PM
LVRR's Avatar
LVRR
Have heard of the timing chain problems in the Challenger but none in the Ram. No mention on 3 other forums I am associated with about the Ram and having any timing chain problems.
What's your source?
Old Apr 9, 2013 | 10:45 PM
dodge29's Avatar
dodge29
New Member
What's your source?
Aren't the engines nearly identical in many cases?
Other forums, but, "you can't believe everything you read on the Internet", right?
What about the relays and the intermittent start problem, no thoughts here?
What's your source?
Old Apr 9, 2013 | 11:04 PM
dodge29's Avatar
dodge29
New Member
Time will answer this question.
Old Apr 9, 2013 | 11:07 PM
dodge29's Avatar
dodge29
New Member
Just another Internet rumor.
Old Apr 10, 2013 | 11:02 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Others have told me that there is an additional relay that is an integrated part of the TIPM itself, which is down underneath the fuse box. They did not explain the relays I am questioning and stopped responding.It seems like Chrysler might have a group out crusing these forums to run damage control. They will answer questions to a point, then they disappear.
To start with, if that was true (highlighted statement) the techs here that happen to be Moderators would have no part of it. Chrysler has screwed us to the wall countless times, so I can tell you that wouldn't happen. We're here for YOU not them.
Also, Mastertech and I plus a few other techs that aren't mods are available to anyone for anything at anytime through PM or email. OR, if you would like one of us to take a look at your problem in the forums and respond, just link it in PM. We don't always see every post of every thread due to the 11-12 hours/6 days we pull.
Old Apr 10, 2013 | 04:03 PM
LVRR's Avatar
LVRR
Nearly identical, yes, but very different also. Do some research. I do believe you will find the timing gear parts on the Ram are different from the Challenger.
I would think with 4 different forums there would be a high percentage of belief.
No thoughts on this.
What's your source?
That is still my question to you.
Sounds like you are trying to be a little snarky here.
Old Apr 10, 2013 | 09:28 PM
dodge29's Avatar
dodge29
New Member
What say we just wait and see?
