Truck Got stuck an had to get it Towed out
Old Apr 11, 2013 | 12:56 AM
littleb115's Avatar
littleb115
Exclamation Truck Got stuck an had to get it Towed out
hey everyone, I'm new here have had my 2012 Ram 1500 4x4 Crew cab Big horn since last summer.
So the issue that i'm kinda freaking out about right now is, I had got it kinda stuck the other day in some snow so I called a tow truck.
The tow truck showed up hooked up to my hitch and told me to put it in neutral. so he pulled me back about 50ft truck running and in Neutral in 2wd possession . Now my questions is did i do this right because I only had the shifter in neutral and not the neutral button on the dash pushed in. could i have screwed anything up? kinda freaking out a lil
Brian
Old Apr 11, 2013 | 03:00 AM
littleb115's Avatar
littleb115
you mean to tell me i got 68 views and not even one person has anthing to say?
Old Apr 11, 2013 | 06:35 AM
oldjeep's Avatar
oldjeep
It was in neutral, its fine. The transfer case was spinning, but it doesn't matter - not like you were having it flat towed for a hundred miles.
Old Apr 11, 2013 | 08:52 AM
DodgeCares's Avatar
DodgeCares
I agree with Oldjeep. 50ft most likely isn't anything to worry about. How does the truck run now? 4WD working? If everything seems fine should be no problem.
Old Apr 17, 2013 | 04:26 PM
cyclone429's Avatar
cyclone429
If you were winched out in n your ok forwards or back wards your drive wheels are still turning, if your locked in 4low or 4hi than your adding stress to the drive train.
Too manny things go wrong pulling out Trucks stuck in 4wd with the stuck trucks driver foot barried in the accelerator.
Old Apr 18, 2013 | 01:23 PM
Brummo's Avatar
Brummo
First of all you weren't stuck! Rams don't do that. You just needed a tow. LOL
Old Apr 18, 2013 | 02:03 PM
Nick Ladd's Avatar
Nick Ladd
im sure if something got messed up youd know it by now
Old Apr 19, 2013 | 09:10 PM
littleb115's Avatar
littleb115
ha YES defiantly not stuck just needed a tow:P
Thanks everyone for your responses it put my mind at ease, also everything is working proper on it 4X4 and all so it should be fine
Old Apr 20, 2013 | 11:24 PM
dundonrl's Avatar
dundonrl
50 ft in with the transmission in neutral, you didn't hurt anything at all. Have you ever coasted in reverse, if so your doing the exact same thing you were doing right there..
Old Apr 23, 2013 | 11:20 AM
shieldsdb's Avatar
shieldsdb
No pictures? Then it didn't happen.
