Tire balance
Old May 2, 2013 | 11:05 AM
kaw550's Avatar
kaw550
Default Tire balance
I just had a set of tires installed. I had been dealing with vibration from the factory wranger due to poor tread wear.
I noticed that with thw new tires there is a slight vibration at highway speeds. I really only notice it if i hold the steering wheel lightly.
I have the 20" wheelss.
Should the tire shop be able to get it 100%?
Old May 2, 2013 | 11:07 AM
oldjeep's Avatar
oldjeep
Yes - they should be able to balance them.
However, you should be asking yourself - if the original tires wore funny and you have a vibration with the new tires, is the problem the tires?
Old May 2, 2013 | 11:34 AM
davidreed's Avatar
davidreed
You probably need a road-force balance. And, if you have the plastic chrome-clad wheels, a special adapter is required to properly mount the wheels to the balance machine.
Got new tires this year (Wranglers) at a local shop and had the vibration issue. Took it back for a road-force balance, now truck drives smooth as glass again. I had to explain to the shop about the need for an adapter, I guess they figured it out.
Old May 2, 2013 | 11:35 AM
kaw550's Avatar
kaw550
The orignal tires were cupped. The tire shop said it was due to the balance. The alignment was also off. I found a local shop that uses a hunter road force machine. I was going to try that but may give the installer anothef try.
Old May 2, 2013 | 11:38 AM
davidreed's Avatar
davidreed
Make sure to mention the adapter for mounting the wheel to the balancer. Not all shops know about it.
Old May 2, 2013 | 12:44 PM
kaw550's Avatar
kaw550
Is the adapter specific to Dodge? I found a Chevy dealership that is close to home and can do it tomorrow.
Old May 2, 2013 | 02:40 PM
davidreed's Avatar
davidreed
Not sure if it's specific to dodge; my guess is that it would be. Google for TSB 22-002-09 for more info on the adapter.
Old May 2, 2013 | 03:33 PM
kaw550's Avatar
kaw550
I called s few places. One said they probably dont but the others said they. Just not sure i beleive them. Even after giving them the part number from the TSB.
