Old Aug 17, 2015, 12:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problem Guides
Print Wikipost
oil leak above filter
Old May 23, 2013 | 10:21 PM
Nick Ladd's Avatar
Nick Ladd
Default oil leak above filter
so i noticed before i did my oil change about 200 miles ago i was getting oil spots in my garage so i got down and looked and noticed the filter was leaking...fast forward to today and i notice yet again another oil spot,got down again and oil filters dry, look above and notice oil marks just above the filter, from what others have told me it could be something with the sending unit anyone have an issue with oil leaking around there? kinda makin me worried seing as the truck just crossed over 10k miles a week ago
Old May 24, 2013 | 09:22 AM
jawsdc's Avatar
jawsdc
10K on a 2011? That's not an oil leak, that's your truck crying!
(no constructive advise btw, other than take it to the dealer and let them repair)
Old May 24, 2013 | 10:28 PM
Nick Ladd's Avatar
Nick Ladd
thats gonna be the first stop just tryin to get an idear of what it could be....not to worried though only lost maybe 1/20th of a quart in 400 miles
Old May 24, 2013 | 11:01 PM
LU229's Avatar
LU229
rotflmao.... i gotta admit, that was fuggin funny...!!!!
Old May 29, 2013 | 10:54 AM
HEMI_ROM's Avatar
HEMI_ROM
I had a similar leak, they tried many things before they finally determined the cylinder head itself was actually defective and leaking from some point - they had to replace the head. That was what finally solved that leak. I'm hoping mine was a freak and yours is something simpler. Let us know what you find out.
Old May 29, 2013 | 11:39 AM
LU229's Avatar
LU229
Hrom,
did you get to see the actual head after it was removed and also where the leak was found...??? What i`m gettin at is, was it really a head manufacturing issue, or maybe it could have been really just a bad gasket issue. Yeah i agree, hope we dont see this become a future oil leak issue.
Old May 29, 2013 | 11:51 AM
HEMI_ROM's Avatar
HEMI_ROM
Originally Posted by LU229
Hrom,
First they thought it was solenoids or injectors as the source of the oil leaking, they changed out some of these things. Then they did the Gasket but it still leaked. After several visits they were as frustrated as I was. Messy driveway...... They told me there was a leak in the head *somewhere* and to make sure they fixed it for me they just replaced the whole head. The leak went away after that, I did not ask to see the head that was pulled. Curiously, that head was removed once before for drilling out a broken exhaust manifold bolt, but that does not mean its related to that.
Old May 29, 2013 | 11:56 AM
oldjeep's Avatar
oldjeep
Could have caused the head to warp by reinstalling improperly, or reusing the head bolts if they had it off a couple times. Odd that they removed it to drill out the manifold bolts though.
Old May 29, 2013 | 12:08 PM
HEMI_ROM's Avatar
HEMI_ROM
Some exhaust manifold bolts on the other head had broke off a few months earlier. They ONLY replaced the broken ones even though I pleaded with them to replace them ALL. Of course the bolt on this head eventually broke and it sheared off at the head surface so they could not remove it. Hence they pulled the head and sent it to the shop to be drilled out. This is the head that was eventually replaced for the oil leak. Today I have brought it back in because there is some horrendous lifter noise? coming out of the new head. They have told me my truck is "jinxed" and I am certain they are sick of seeing me.
Old May 29, 2013 | 12:10 PM
oldjeep's Avatar
oldjeep
If you have lifter noise in the head of a pushrod V8, you've got some really big issues
