'09 with lifetime powertrain
Old Jun 10, 2013 | 07:15 PM
Brummo's Avatar
Brummo
Default '09 with lifetime powertrain
Have a quick question. I have an '09 with lifetime powertrain warranty. I just had a transmission flush 2 weeks ago and then left for vacation. The truck sat for a week in the garage and when I got home the pan was leaking from the front of the gasket. I have called the dealer to ask why all of the sudden it is leaking after a flush of the system, so I am taking it back. My question is, aren't gaskets covered under the powertrain warranty? The way I read it they are.
Transmission: transmission case and all internal
parts; torque converter; speed sensors; pressure sensors;
drive/flex plate; transmission range switch; transmission
control module; bell housing; oil pan; seals and gaskets for
listed components only.
Old Jun 10, 2013 | 08:32 PM
oldjeep's Avatar
oldjeep
Should be. Seems odd that the gasket would leak after a fluid replacement (nobody "flushes" transmissions any more). Are you sure it is the pan and not the TC seal?
Old Jun 10, 2013 | 08:59 PM
CarGuyOhio's Avatar
CarGuyOhio
Yes, leaks are covered. This is also probably a good time to remind people you must take your vehicle into the dealership to have it "inspected" in order to maintain the lifetime power train warranty. I think it is eveyr 5 years, my memory is fading a little on that part.
Old Jun 10, 2013 | 09:23 PM
oldjeep's Avatar
oldjeep
Yes. 5 years something like 30 days on either side of the in service date.
Old Jun 10, 2013 | 09:42 PM
Brummo's Avatar
Brummo
Yes from what I have read it has to be every 5 years within 60 days of the anniversary date. I take it to the same place every time for service and they supposedly do an inspection every time.
So I should expect this to be at least covered by them from the service, if not the lifetime powertrain warranty.
...and yes it is coming from the transmission pan gasket I have been under there 3 times now to dry it up. Its not a huge leak just a drip...but that is too much for me since it wasn't there before.
Could an overfill cause this too? I started the truck, put it in neutral and pulled out the dipstick. It was between the cold and hot on the stick..
Old Jun 11, 2013 | 05:18 PM
stlram's Avatar
stlram
Just wondering how many miles did you have on your truck when you flushed your tranny?
Old Jun 11, 2013 | 05:46 PM
kddsRam's Avatar
kddsRam
surprised they did not drop the pan as part of the trans service for a 4x4 truck.
Old Jun 11, 2013 | 05:48 PM
mike2810's Avatar
mike2810
From my 09 warranty book.
Lifetime Power Train Warranty
NOTE: MANUAL TRANSMISSION CLUTCH
PARTS ARE NOT COVERED AT ANY TIME.
Seems you should be covered.
Old Jun 11, 2013 | 07:07 PM
Brummo's Avatar
Brummo
Originally Posted by stlram
just wondering how many miles did you have on your truck when you flushed your tranny?
37,000
Old Jun 11, 2013 | 07:24 PM
A05GSHO's Avatar
A05GSHO
My 07 pan gasket was leaking and I had the lifetime powertrain warranty on it and no the leaking gasket wasn't covered so I had the trans flushed which included a new pan gasket as part of the flush job.
