front winch trays recommendations
Old Jun 24, 2013 | 06:28 PM
lelikmed's Avatar
lelikmed
Default front winch trays recommendations
Any one installed a electrical winch on the front?
I have 2012 3500 HD.
I know Westin makes winch trays for 2500/3500 - $250 on Amazon
Anybody have tried this tray?
Any other recommendations?
What are good winches?
I will be pulling 3000 -4000 lbs.
Old Jun 24, 2013 | 06:34 PM
oldjeep's Avatar
oldjeep
What in the world are you planning on pulling with it that only weighs 3-4K? Normally a winch is for recovering the vehicle and you wouldn't put anything less than a 10-12K winch on the front of a 1 ton.
Assuming you are talking about this:
http://www.amazon.com/Westin-46-22585-Winch-Mount-Tray/dp/B004AJ9NXW/ref=au_as_r?ie=UTF8&Make=Ram%7C1168&Model=3500%7C16229&Year=2012%7C2012&carId=002&n=15684181&newCar=1&s=automotive&vehicleType=automotive http://www.amazon.com/Westin-46-22585-Winch-Mount-Tray/dp/B004AJ9NXW/ref=au_as_r?ie=UTF8&Make=Ram%7C1168&Model=3500%7C16229&Year=2012%7C2012&carId=002&n=15684181&newCar=1&s=automotive&vehicleType=automotive
Then you need to make sure you buy a front mount winch (generally 10-20K)
For winches I would be looking at Warn and maybe Ramsey
Old Jun 24, 2013 | 06:55 PM
lelikmed's Avatar
lelikmed
http://www.amazon.com/Westin-46-2258...ype=automotive
This is tray I was talking about... I need a winch to pull out my rally car... just in case...
Old Jun 24, 2013 | 07:01 PM
oldjeep's Avatar
oldjeep
Sounds like a tow strap would work just as well for that.
Old Jun 24, 2013 | 07:57 PM
lelikmed's Avatar
lelikmed
I thought about it too... tow rope and regular hand winch puller ... it's just electrical is easier and some time road is narrow so no place to pull back especially this big truck.
Old Jun 24, 2013 | 08:54 PM
oldjeep's Avatar
oldjeep
Then you should be able to get by with a 10K winch. Just remember that 3-4K stuck is not going to move with a 3-4K winch, the rating is for a rolling load - basically on flat ground.
